Thomas
Epic Contributor
- Joined
- Apr 6, 2000
- Messages
- 31,108
- Location
- Lebanon,NH.
- Tractor
- Kubota B2650HSD w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
Try little down pressure from FEL..works fine.
It is normal to get what is called wind up in the driveshaft to the front axle. Usually when driving on pavement or hard packed dirt roads. DO NOT try to force the lever down as this will damage the linkage.
Generaly speaking, if you roll the tractor backwards slightly, it should shift out of gear without a problem. Another way is to use the loader to lift the front wheels off of the ground and allow the the driveshaft to relax and then shift out of four wheel drive.
