Disconnecting BH to connect grapple LK3054
   / Disconnecting BH to connect grapple LK3054 #1
bob2230
Anyone know if I can disconnect the the two hydraulic lines going to the Kelley BH and connect them to a W R Long electric over hydraulic valve to operate a grapple ?? The lines are now connected to the A port on the tractor selector valve and the FEL valve.
Thanks
Bob
   / Disconnecting BH to connect grapple LK3054 #2
That will work fine-just make sure the valve is rated for the same GPM as you tractor is. The is lots of info like this in the hydraulics forum if you search:D
   / Disconnecting BH to connect grapple LK3054 #3
Your tractor should be at 10 GPM or less, I think it was 7.5 or so prior to 2004 or so.
Good luck. I've got the lk3054XS, I think the XS was when the 10GPM started?
Joel
Kennyd, thanks. I your reply to ditzel, I think you mention that the lines should be connected to each other when not connected to BH. If I'm not connected to my BH or the Long valve, should I connect the two to prevent pressure also ?
Bob
   / Disconnecting BH to connect grapple LK3054 #5
Bob
Yes, They MUST be connected together! These lines have the full flow of the hydraulic pump ALL THE TIME. The fluid must go somewhere!
New/Unused Electric Golf Cart (A57453)
New/Unused...
Gradall 53409-45 Telehandler, Turbo Diesel Engine, 45' Reach, Rear Steer, 60" Forks, 6,699 Hours (A59076)
Gradall 53409-45...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
1992 TRI CITY DUMP TRAILER (A58018)
1992 TRI CITY DUMP...
