Disconnecting BH to connect grapple LK3054
   / Disconnecting BH to connect grapple LK3054 #1
bob2230
Anyone know if I can disconnect the the two hydraulic lines going to the Kelley BH and connect them to a W R Long electric over hydraulic valve to operate a grapple ?? The lines are now connected to the A port on the tractor selector valve and the FEL valve.
Bob
   / Disconnecting BH to connect grapple LK3054 #2
That will work fine-just make sure the valve is rated for the same GPM as you tractor is. The is lots of info like this in the hydraulics forum if you search:D
   / Disconnecting BH to connect grapple LK3054 #3
Your tractor should be at 10 GPM or less, I think it was 7.5 or so prior to 2004 or so.
Good luck. I've got the lk3054XS, I think the XS was when the 10GPM started?
Joel
Kennyd, thanks. I your reply to ditzel, I think you mention that the lines should be connected to each other when not connected to BH. If I'm not connected to my BH or the Long valve, should I connect the two to prevent pressure also ?
Bob
   / Disconnecting BH to connect grapple LK3054 #5
Bob
Yes, They MUST be connected together! These lines have the full flow of the hydraulic pump ALL THE TIME. The fluid must go somewhere!
2007 Toyota Camry Sedan (A50324)
2007 Toyota Camry...
Swict 66" Bucket (A50121)
Swict 66" Bucket...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2018 Ford F-150...
2006 Capacity TJ7000 (A50120)
2006 Capacity...
2018 Bobcat T870 Skidloader (RIDE AND DRIVE) (A50774)
2018 Bobcat T870...
Skidloader Forks (A50774)
Skidloader Forks...
