Disconnecting A FEL On A Ford 3000
   / Disconnecting A FEL On A Ford 3000 #1
Shepp
Toronto Ontario
Ford 3000
Hello everyone: I am a new member to this Forum. I recently purchased an old Ford 3000 diesel. Not sure of the year. I haven't quite deciphered the numbers on the engine block yet. She ran great all the way home which was about a 30 mile trip. Graded my driveway a few times with it then the clutch froze. Looks like I am going to have to split her. I tried all the tricks including soaking the clutch with brake fluid, but she still won't release. The biggest problem I have right now is dismantling the FEL. It is an old Freeman loader that attaches to the front of the engine block and the rear axle. I thought I could just release these bolts and back her out from the loader, but I quickly realized that the big vertical support arms would be in the way of the front wheels. Has anyone removed one of these loaders before? Am I going to have to dismantle the entire thing piece by piece or is there an easy way.
Thanks. Shepp
   / Disconnecting A FEL On A Ford 3000 #2
It seems to me (I'm only speculating here) that you could disconnect the loader at the point of attachment at the rear axle. Then when you split it the back half would move backwards and the loader and front would stay stationary. Of course doing that on the dirt might be a challenge. Good luck and post lots of pictures:)
   / Disconnecting A FEL On A Ford 3000 #3
i think it's likely attacjed tot he front bolster and not the front of the engine block.
also.. the numbers on the engine block won't help you as much as the numbers on the trans bellhousing aft of the starter. there is a machined spot and 3 numbers... usually only 2 make it tot he machines spot.. and one may be in the rough...
I considered just disconnecting the loader at the axle and leaving the front on, but it sure would make spitting the tractor harder with those support arms in the road. Since I am in the middle of the bush near my camp I was planning on building a solid floor with 2X6's layed flat side down and covered with 3/4" ply. I have seen this done before for temporary dance floors outside. I can put a pump jack on this.
Thanks Soundguy: The machined spot that you are talking about. Does it appear to be a 4" square with 2 holes in it? I have looked here, but could not see any numbers. The only numbers I have found are on the right side engine block. C5NN6015 T1 and another set 6W14. On the transmission housing they are C5NN7096 AA and R761966. The next time I am at the camp where the tractor is I will look closer at the machined spot aft of the starter.
Shepp
   / Disconnecting A FEL On A Ford 3000 #6
you are seeing raised casting numbers. we are looking for STAMPED in numbers on that bellhousing flange.. and yes.. it has bolt holes in the face..e tc..
I checked out the machined spot for the numbers. After scraping away the dirt and grease I found them. 6M29 and B 061972.
Thanks Soundguy
IMG00757-20120829-1255.jpgAfter looking things over. I be leave this is the best method. Just leave the front loader attached and disconnect the rear supports like you said. It was a bit of a pain with all the extra support arms in the way, but managed anyhow. Now I just have to get the drag links disconnected. They are not releasing.
   / Disconnecting A FEL On A Ford 3000 #9
Shepp..If you havent done it already I had a freeman loader like that on a mf35... Best way to remove is to detach the loader arms at the pivot point, attache a chain or come along to to a post or tree. Raise the arm out of the pivot points. disconnect the hoses, Back the tractor out of the arms. Disassemble the Left and right supports from the front brackets, detach from the rear axle and set them off to the side.. did this many times by myself. Makes reassembly easier.
Good luck on the clutch sounds like a PP or fork issue
Thanks Bucktaker: I have already started to split the tractor with the bucket on, but thanks for the advice. I will use it in the future if I ever need to replace the FEL. It was a pain getting the wiring, starter motor, hydraulic pump ect off with those support arms in the road, but after a few choice words I managed anyhow. My big problem now is the steering draglink arms. Cant seem to pop the ball joints off. I will attach a photo of some late night travelers at my camp where I have the tractor.Three Moose.jpgBull Moose.jpg
Shepp
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
1265 (A50490)
1265 (A50490)
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
2013 Ford Explorer AWD SUV (A50324)
2013 Ford Explorer...
