Disconnected FEL and now lift not working
   / Disconnected FEL and now lift not working #1
mikereid
Jackson, GA
Yanmar YM1700
I disconnected my FEL and now my rear lift is not working.
I am sure its something simple but I can't figure it out.
I'ts a 336D
   / Disconnected FEL and now lift not working #2
may be same problem I had when I took hoe off mine and lift wouldn't work. I had to switch lines I had reconnected and then it worked
Yep, I hooked them up together, works great.
DUH, sometimes the simple things elude me.
   / Disconnected FEL and now lift not working #4
If you are using Quick connects , you might try as I have done to keep from mistaking them, I use one of each male & female , then the matting male & female on opposite ends of the hyd lines, when I remove the FEL I have a small hose with male on one end female on the other to re-connect the circuit,
in any case glade it was a simple fix for you :thumbsup:
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
Ammco Brake Machine (A53424)
Ammco Brake...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
Ford F450 Bucket Truck with Altec AT200A Boom (A55218)
Ford F450 Bucket...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
