Disconnected FEL and now lift not working
   / Disconnected FEL and now lift not working #1
mikereid
Jackson, GA
Yanmar YM1700
I disconnected my FEL and now my rear lift is not working.
I am sure its something simple but I can't figure it out.
I'ts a 336D
   / Disconnected FEL and now lift not working #2
may be same problem I had when I took hoe off mine and lift wouldn't work. I had to switch lines I had reconnected and then it worked
Yep, I hooked them up together, works great.
DUH, sometimes the simple things elude me.
   / Disconnected FEL and now lift not working #4
If you are using Quick connects , you might try as I have done to keep from mistaking them, I use one of each male & female , then the matting male & female on opposite ends of the hyd lines, when I remove the FEL I have a small hose with male on one end female on the other to re-connect the circuit,
in any case glade it was a simple fix for you :thumbsup:
Sterling AT (A55301)
2016 FREIGHTLINER CASCADIA (A53843)
2016 FREIGHTLINER...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A54607)
2008 AAR MOBILITY...
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
