Discbine, 2pt or hitch. pros and cons
   / Discbine, 2pt or hitch. pros and cons #11
What model and hitch type?
JD 1470 pulls from drawbar.
Your's doesn't have the gyrodine hitch. With a gyrodine hitch the pto shaft stays straight all the time. W e bought a Kuhn 3150 last year with the drawbar hookup & the gyrodine hitch & when turning there is no noise at all from the shaft when turning.
It does have a special part that attaches to my drawbar to extend the distance of the PTO shaft, it says is supposed to get rid of chatter completely cause it will make the joints at even angles and distance.
   / Discbine, 2pt or hitch. pros and cons #12
corey9212
Do you have the tractor drawbar set at the correct length(540 rpm-14" or 1000 rpm -16")?? Are the 2 u-joints on the telescoping shafts in correct phase? Wear in the sliding drive shafts can let u-joints get out of phase(time) enough to chatter.
   / Discbine, 2pt or hitch. pros and cons #13
Not mine, mine chatters like a nudist outside in a cold winters day. :p
You apparently didn't understand my descripton of swivel hitch. You have an equal angle hitch, and it seems to be one that has some shortcoming, either in setup or condition.
   / Discbine, 2pt or hitch. pros and cons #14
Yes,your's has the equal angle hitch. I had two 1460 john deere mowers years ago with that hitch.
   / Discbine, 2pt or hitch. pros and cons #15
I have a Kuhn and I opted for the 2 pt hitch. I love it almost all the time, the one time I don't like so much is when hitching up - it's a pain! But once done it pulls very nicely, turning at close to 90 degrees with absolutely no driveline clatter is an experience I never had on the old haybines. Your hitch arms do need to be able to lock firmly in place to prevent side to side sway on uneven ground though. The NH I run the discbine on has pins to lock the arms in a set of hole - chains would work better for this as they could be tightened snuggly.
So if I was going to hook the discbine to a dedicated tractor for the entire mowing season, it would be a 2 pt hitch hands down. Since my NH has to do the mowing and the baling I do a lot of hitching/unhitching of the discbine. I do curse it a little bit then. :)
Yeah that would definitely he an issue for me as we only run 3 tractors here so we do a lot of hitching and unhitching. I hear the drawbar hookups with the gyro system does really well also, maybe not quiet as well as the 2pt but a lot better than the older systems.
   / Discbine, 2pt or hitch. pros and cons #18
There's a Kuhn FC 243 RTG here on the farm. My wife and son picked it up used for a song with less than 200 acres on it. It has the 2 pt. hitch with the Gyrodine system. You can turn it back on itself, more than 90˚, and there's no drivetrain noise at all. It's not hard to hook because the hitch arms swing and twist side to side. It's the easiest hook up 3 point hitch implement I've ever seen. Getting the chains set up right the first time takes longer than anything.
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2017 Ford F550 (A55973)
2017 Ford F550...
RoGator RG1100C (A55315)
RoGator RG1100C...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55315)
Case Wheels for...
UNUSED FUTURE 32"...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
