Disc plow
/ Disc plow #1
johan3400
Western Illinois,just this side of heaven
Kubota L3400 FEL
Has anyone ever used a disc plow to work up dirt after cleaning brush? I have heard they are good in areas where roots could be a problem. Today I found a two disc 3pt model which I can purchase at a good price. Would my 3400 pull this? I would use it after pushing out mulit-flora rose bushes and hedge trees.
/ Disc plow #2
I don't know the stats on your 3400, but keep in mind that farmall cubs pulled single disc plows, and allis chalmers 'G's also pulled single disc plows. Thos tractors are 10-14 hp.
A ford N series will pull a standard 2 bottom plow 10-12-14 or a single 16. A for N is about 23-27 hp depending on where you measure it ( belt/drawbar/pto.. etc. ) I'd have to guess if your kubota is in that range. (25+hp ). you will be ok pulling that plow. Keep in mind that plowing really benefits from a draft sensing hitch.. but you can run it with plain position control.
I've always thought disc plows look neat.
Soundguy
/ Disc plow #3
I would venture a guess that it would. When I was young, we pulled one with a Farmall 140.
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2007 International School Bus (A64194)
2007 International...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
2007 INTERNATIONAL 7600 6X4 T/A CONCRETE TRUCK (A66091)
2007 INTERNATIONAL...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
Gravely Zero Turn Mower (A64194)
Gravely Zero Turn...
