Disc or Tiller
/ Disc or Tiller #21
if u are planting Bermudagrass why dont u plant sprigs it is a whole lot easyier and less work all u need to do is disc real good spread the sprigs with a sprig are a old manure spreader and then set disc ganges straight and dics the sprigs in and be on your way
+1 That's usually how it's done around here too. The insertion method may vary, but typically using sprigs.
/ Disc or Tiller #23
I've found that for our ground, (very rocky, looks like more rocks than soil;)) I use the disc first. It's a big heavy 18 ft IH and really cuts the ground, I then run the cultipacker over it and then plant. Any type of cultivating or harrowing brings the rocks up, big and small. If I'm planting rye, wheat, or a cover crop where I'm broadcasting I then run the cultipacker over it again to press the seeds in.
/ Disc or Tiller #24
That looks like a Brillion 12-14 ft Transport cultipacker. Super nice machine. Ken Sweet
/ Disc or Tiller #25
Just use the rototiller.:D
I have a chisel plow, a disk and a 6' rototiller. I keep going back to the tiller because its a single pass, seed, culitpack, done. I do a total of 6 acres of plots on my own lands. Tiller works well for making and seeding trails in the woods if you ever wanted to do that as well. I have a King Kutter version; there are better ones out there but for the money, and the abuse it has taken it has been a great piece of equipment. My only complaint on the KK is the paint doesn't hold up well. Going to paint it Kubota orange this winter.
-BG
/ Disc or Tiller #26
Here in NY, it depends on how long the ground has sat idle. If it is sod ground, I usually plow it under, pulling a 5' roller behind the plow to flatten and conserve moisture, and then hit it lightly with a disc. Planting three acres of corn.( enough for my chickens and for the deer through February). Once the ground has been worked one year, hit the corn stalks with a disc, chisel, and then rototill seeding it to soybeans in spring, wheat in the fall. I also do alot of frost seeding(usually clover seed) walking on grass seed in the fall with the wheat or old soybean fields. I roll only after I plant in spring( tends to pack like the road). I plant alfalfa hay seed before Aug 15 th, that is when the roller is out in force. So actually, owing a plow, disc,chisel, roller,and rotor tiller is nice if you can. I think rotor tilling by itself on heavier ground doesn't till deep enough, so plow first. This is what works for me. trac
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2008 Ford E-350 Cargo Van (A61573)
2008 Ford E-350...
John Deere XUV825E (A61307)
John Deere XUV825E...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
New/Unused CFG Industrial MH12RX Mini Excavator (A65579)
New/Unused CFG...
