Disc or Till Pasture?
   / Disc or Till Pasture? #1
lazyhorsefarm
Elk River, MN
none
I just moved into a property with approx 2.5 acres that is grown over. I want to turn that into a pasture area but there are some ruts/holes and I need to get the ground leveled. I haven't found anyone to disc the area, but have found someone who will come out and till with a tractor/tiller. Will that work or am I making a mistake by doing the wrong process?
   / Disc or Till Pasture? #2
Have you considered plowing then a disc or tilling.
Depending on the current surface both a disc and tiller might not be the best initial approach. You might have to make numerous passes to have an effect on the sod with either.
   / Disc or Till Pasture? #3
Yea, plowing and discing would be the better choice. Then you can seed with the pasture mix of your choice. A 3 point tiller won't do much in most cases. Get a great "massage" though bouncing on the tractor.
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
Genie GTH-644 (A50490)
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51694)
2018 Suzuki...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2003 Ford F-150...
