Disc or Till Pasture?
   / Disc or Till Pasture? #1
lazyhorsefarm
Elk River, MN
none
I just moved into a property with approx 2.5 acres that is grown over. I want to turn that into a pasture area but there are some ruts/holes and I need to get the ground leveled. I haven't found anyone to disc the area, but have found someone who will come out and till with a tractor/tiller. Will that work or am I making a mistake by doing the wrong process?
   / Disc or Till Pasture? #2
Have you considered plowing then a disc or tilling.
Depending on the current surface both a disc and tiller might not be the best initial approach. You might have to make numerous passes to have an effect on the sod with either.
   / Disc or Till Pasture? #3
Yea, plowing and discing would be the better choice. Then you can seed with the pasture mix of your choice. A 3 point tiller won't do much in most cases. Get a great "massage" though bouncing on the tractor.
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
5420 John Deere Tractor (A52384)
5420 John Deere...
2025 CFG Industrial M-DRG (A50123)
2025 CFG...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
Icon Electric Utility Cart with Dump bed (A51694)
Icon Electric...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
