Disc mower lubricant
   / Disc mower lubricant #1
repete
SW Washington
L2550DT IH584-4WD
I have a 9' disc mower for hay cutting and it calls for EP 320 gear lube in the disc assembly. Anyone know where this lubricant is available. I can find it in 55 gallon drums but I do not need 50 years worth....
   / Disc mower lubricant #2
Have you tried your local OEM Equipment dealer? AMSOIL has a 250 ( I don't see anything heavier) and it is fully synthetic and available in quarts. Here's a link if that's an option for you. Free shipping promotion this month too. SEVERE GEAR(R) SAE 25? SRT - AMSOIL You could also call tech support ( a real live person) at (715) 399-TECH (8324) for their opinion if this lube is suitable.
Dutchy
Dutchy
When I contacted the dealer they just said they drain the EP320 and fill it with regular 90 wt gear lube. I prefer to use what the manufacturer specs. No response to a message left with the manufacturer sadly. I know EP320 is out there but finding it in 5 gallon pails is my issue.
   / Disc mower lubricant #4
Yep, I agree. However, if you check the specs for the above AMSOIL gear lube both the 190 and 250 exceed the specs for 320. The 190 is the most similar though. Contact them and see what they say. Gear Lube - AMSOIL Dutchy
Thanks!
   / Disc mower lubricant #6
You never stated the brand of disc machine but, I use 80-90 GL5 in my NH disc bine and have for years. NH wants you to use Ambra but I use Shell gear oil. Buy it in 5's as I have other gearboxes on the farm. Change it ever 2 years.
Mine specifies 80-90 in the gearbox but the EP320 in the disc drive system. It is a Bush Hog HMG9.
   / Disc mower lubricant #9
They may of been directed by the manufacturer (TSB) to do so.
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
Pickup Instructions (A47477)
Pickup...
SCAN FOR HAULING AND FINANCING INFORMATION (A54756)
SCAN FOR HAULING...
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
