Disc Harrow Selection For 18-45 Horsepower Tractors (Revision 2b)
   / Disc Harrow Selection For 18-45 Horsepower Tractors (Revision 2b) #31
Earlier, on another thread, I remember reading about a technique to prevent the discs from picking-up soil which sticks between - and gets packed in tight. It involved chains, but I can't locate the post now.
Can somebody help? This happens to me, particularly on the notched discs.
Scrapers
   / Disc Harrow Selection For 18-45 Horsepower Tractors (Revision 2b) #32
I hit the button too quick . You need real spring loaded scrapers , not chains . Jeffs info is very good . A disc is not a primary tillage tool . Chisel plow or ripper , then disc . TTH
A disc is not a primary tillage tool . For primary tillage, chisel plow or rip, then disc .
A moldboard plow / turning plow is the most traditional of primary tillage implements.
   / Disc Harrow Selection For 18-45 Horsepower Tractors (Revision 2b) #35
I have the Fred Cain cultivator (same type of product as the all purpose plow). It is a fantastic initial soil preparation tool. Something that will break the ground prior to discing. I use mine prior to rototilling.
   / Disc Harrow Selection For 18-45 Horsepower Tractors (Revision 2b) #36
Disk’s are a common primary tillage tool In agriculture. All it takes is the proper sized equipment.
Tillage equipment:
   / Disc Harrow Selection For 18-45 Horsepower Tractors (Revision 2b) #37
This is a encyclopedic summary! Excellent. Thanks for taking the time and effort.
   / Disc Harrow Selection For 18-45 Horsepower Tractors (Revision 2b) #38
I have a 4 wd 4410 JD. I intend to disc up a section for a food plot. The section
was tilled 2 years in a row 2 years ago but is now regrown with field grasses. It has been brush hogged. I know nothing about using a disc harrow. The soil I intend to disc is hard clay.
A section of land is 640 acres.
Hard for me to imagine a food plot of that size ~~ but maybe so.
Please clarify.
   / Disc Harrow Selection For 18-45 Horsepower Tractors (Revision 2b) #40
I was referring to a section of my property. Approximately 2 - 3 acres. Thank you for correcting me. Im sure no one would be able to answer my question without that distinción.
(1) 225 Gallons of Bleach (A51573)
(1) 225 Gallons of...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2025 New/Unused Wolverine 36in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
New/Unused CFG Industrial MX12RX Mini Excavator (A51573)
New/Unused CFG...
40' CONTAINER (A51244)
1992 GROVE CRANE (A52576)
1992 GROVE CRANE...
