disc harrow or rototiller
   / disc harrow or rototiller
If the slip clutch is in good shape it will protect things. You should be loosening it up & making sure it slips properly. The clutch on mine is locked up tight every spring. Even when the springs are completely loose it will cut half way through a 2x4 jammed in the tines before the clutch let's loose.
Good point. I haven't checked mine in years. I'm assuming that I'll need to buy a new driveline anyways because mine would be too short, so I'll also start out with a new slip clutch.
   / disc harrow or rototiller #22
When I need to repair or lengthen a pto drive shaft, I buy a matching length of the tube, and weld it on,
V both of them out, clamp them tight in a piece of angle iron and make a few pass' to fill the groove It's a cheep way of fixing the problem, and it's a permeant fix.
SR
SHOPMADE MANIFOLD TRAILER (A58216)
SHOPMADE MANIFOLD...
1965 Rogers Low Boy Trailer (A57453)
1965 Rogers Low...
200 GAL. POLY TANK (A58374)
200 GAL. POLY TANK...
CASE 610 Sprayer System 2000 Gallons (A56436)
CASE 610 Sprayer...
2012 FORD F-550 SUPER DUTY (A58214)
2012 FORD F-550...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
