Disc Harrow for Kioti DK40HST?
   / Disc Harrow for Kioti DK40HST? #1
VT365
What size disc harrow will my Kioti DK40HST Comfortably pull in a wide range of soil conditions? 7', 8' wide?
   / Disc Harrow for Kioti DK40HST? #2
Are you talking about a transport disc or a three point hitch? I am pulling a 10 ft. transport disc with my 45 and it pulls it well (In 4wd.). Just my opinion but I think you would be safe with an 8 ft. but be sure you can lift it easily if it's 3 ph. Not sure what your 3ph capacity is with the 40. If you have a loader I would take the bucket off and leave the loader arms on for extra weight up front.
   / Disc Harrow for Kioti DK40HST? #3
My NHTC40DA will pull our 6-1/2ft 3point disc cutting almost to the hubs - needs 4wd low & about 2500 rpm to do so (this is in already plowed ground). Our soils are pretty heavy but not gumbo.. Your soil conditions & moisture will affect how yours does.
   / Disc Harrow for Kioti DK40HST? #4
I pull a 8' 3pt unit with a DK35 without any problem, I just don't adjust the gangs to the most aggressive setting.
   / Disc Harrow for Kioti DK40HST? #5
And if your close to me, I have a six and a half foot 18/20" in like new condition, I think I have a picture in ( my other gallery )
Jim
   / Disc Harrow for Kioti DK40HST? #6
How come?
   / Disc Harrow for Kioti DK40HST? #7
Just feel that the more weight you have up front when pulling heavy ground engaging implements the better off you are. I will be putting 600 lbs of weights on the front of my old IH to pull a 4 bt plow and a disc.
   / Disc Harrow for Kioti DK40HST? #8
Definitely agree with that, I just didn't understand why you woud remove the bucket. Better visibility?
   / Disc Harrow for Kioti DK40HST? #9
i don't think you're going to have any trouble with either a 7/8' harrow. like TwinWillows said, soil condition will determine what you can pull. i've attached a pic of my DK55 pulling a transport harrow (think it's 10'.. never measured it).
pf
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
Case 950 8 Row Air Planter (A53473)
Case 950 8 Row Air...
Krause Dominator 4850-18ft (A53473)
Krause Dominator...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
2013 Infiniti M37 Sedan (A53424)
2013 Infiniti M37...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
