Disc for Kubota M5040
   / Disc for Kubota M5040 #1
bossgobbler
Southeast Ohio
Kubota
Good afternoon! I am looking into buying a disc for my Kubuta M5040. I will need it mainly for food plot prep on our land and a few other farms around our area. We live in southeast Ohio with a mix of flat ground and hills. I don't have much of a farming background beyond some food plots and talking with other farmers. I have a few questions about size and price. I will just give them in a list style. Any help that you would be willing to give would be greatly appreciated. Thanks in advance!
Tractor is about 4,000lbs. I have loaded rear tires which helps add some weight. I also have an la1153 front end loader. With that added weight I would assume it weighs somewhere around 7,000lbs(someone else may know)
It is 4x4 and 50hp with r4 tires
I want to be able to pull it nicely through smaller and larger plots. The smallest being 1/8 acre and the largest being 2-3 acres and maybe the occasional 5 acres, although that will be rare.
As far as budget: I want something that will get the job done but doesn't run the bill up too much. I doubt new is a good option. I am just looking into these right now but want to buy one fairly quickly. I am buying a rotary cutter, disc/tiller, cultipacker, and maybe plow.
Questions:
What size disc would be appropriate? Please give width and actual disc size.(keep in mind maneuverability in food plots)
I am right in assuming I want a 3pt type disc?
Benefits or concerns with a disc vs a 3pt tiller?
Will a plow be beneficial before using the disc? Some ground has never been worked, others have been.
If I need a plow, what size?
I will someday probably own both a disc and a tiller but right now I can't buy everything.
Try to give me a size and average cost of a usable, used disc, plow, cultipacker, 6' rotary cutter.
I know that's a lot of reading and many questions. Sorry! Thanks for your help!
Tyler
   / Disc for Kubota M5040 #2
I have one laying around ( disc pull behind ) used once and its labled indicating its designed for a tractor having 30 hp or more. guessing hp of tractor is the defining element.. BTY if you bought one what did it cost???
I'm thinking on getting rid of mine and would know what to expect would be a reasonable price.
TKS NOSPELL
   / Disc for Kubota M5040 #3
I AM IN THE PRCESS OF REVISING THIS THREAD. SORRY, NO PICUTURES UNTIL I POST REVISION IN A FEW DAYS.
DISC HARROW SELECTION For 18-45 HP Tractors (Release 2b)
Disc Harrows come in numerous types. However, for 18-45 horsepower tractors the three point hitch mounted, Tandem Disc Harrow, secondary tillage implement is ubiquitous.
Tandem Disc Harrows are manufactured in two structural types: Angle Iron Frame and Box Frame. Box Frame Disc Harrows are stronger, heavier, have greater adjustability of the gang angles and are less prone to working loose than Angle-Iron Frame Disc Harrows. If the budget allows, purchase a Box Frame Disc Harrow.
February 28, 2013 I took delivery of a Howse, box-frame, 3-Pt. disc harrow, Model DLHT16822B, from my local Kubota/Howse dealer. The dealer, from who I bought my tractor, recommended the Howse DLHT. At the time I was researching Disc Harrows from Land Pride, Everything Attachments (ETA), TSC/Countyline and Monroe Tufline
Howse describes the DLHT series as MEDIUM DUTY. Howse DLHT is a 16/18 Disc Harrow, meaning 16 discs, each 18" in diameter, spaced 9-1/2" apart. It cuts a swath nominally 5'-6" in width, adjustable by sliding the disc hangers in or out. The Howse DLHT16822B weighs 587 pounds. It has a 1" axle on sealed flange bearings. (There is a T-B-N consensus that to cut vegetation Disc Harrows should have 40+ pounds weighting each disc. My Howse has 37 pounds weight per disc; at times I wish for a bit more weight.)
Howse sells DHT Series HEAVY DUTY Disc Harrows, with 20" discs and 1-1/8" axles, in 16/20 and 20/20 configurations.
My primary Disc Harrow objectives involve CUTTING; opening new game feed plots, maintaining vegetation free fire breaks and vegetation control along woodland trails. Harrow weight on 16 discs, rather than 20 discs, puts more cutting weight on each disc.
Tractor users with SMOOTHING (plow furrows) as their priority should consider the 20/18 (7-1/2" between discs) or 20/20 configuration.
Disc Harrows are available with two types of discs: notched and smooth. Notched discs cut pasture grass and crop stubble better; in open soil notched blades jerk out trash, meaning vines and tree roots, which stick in the notches. Notched discs deform easier than solid/smooth discs working rocky soil. Thicker discs, if notched, are less prone to deform in rocky soil than thinner notched discs.
Smooth discs ride over some vegetation that notched discs will cut through.
Standard configuration for Howse Disc Harrows is notched discs front, notched discs rear.
((Synonyms for individual discs: wheels or pans.))
Discs for compact tractor harrows come in 16"-18"-20"-22" diameter. Generally speaking sub-compact tractors will use 16" diameter notched discs, mid-size compacts 18" diameter notched discs.
Forty (plus) horsepower utility tractors may opt for heavier 20" or 22" discs, sometimes notched discs on the front gang and smooth discs on the rear gang. The three point hitch Top Link is used to adjust relative front/rear gang pressure on soil. Longer Top Link: more soil pressure from rear gang. Shorter Top Link, more soil pressure from front gang.
Issues with disc diameter are concavity, wear, harrow weight and clearance lift. Smaller diameter discs generally have less concavity (less "float") than larger discs, so they theoretically penetrate easier; smaller discs are thinner/sharper than larger diameter discs. Larger diameter discs generally have greater concavity, so move more soil laterally. Larger diameter, thicker discs wear longer before requiring replacement. Larger diameter, thicker discs add to harrow weight, which offsets "float", improving penetration.
Replacement 18 inch discs are available in 3mm, 3.5mm, and 4mm thickness. Replacement 20 inch discs are available in 3.5mm, 4mm, 4.5mm, 4.76mm, 5mm and 6.35mm thickness. As shown, diameters and thickness overlap. Thicker discs are heavier. (Agri-Supply offers 516 individual disc types on its web site.)
Discs of larger diameter require more lift from the three point hitch. Clearance can be an issue when crossing ditches, rough ground and loading or unloading a tractor mounted Disc Harrow from a trailer.
My Howse has a dropped double clevis (Photo #11) to receive draw pins. A dropped clevis is desirable on a Disc Harrow for an 18-38 horsepower tractor; it allows the 3-Pt. to lift the harrow earlier. Note pictures showing my Howse in the air. Minimum disc height above ground is 14-1/2", greater than 14" ground clearance of my B3300SU tractor.
I prefer a wide double clevis, which accepts separate draw pins, to protruding, frame-mounted "open" draw pins. The double clevis provides a stronger tractor/harrow connection, which distributes draft strain. TSC Countyline by Tarter, 84 Disc Harrow, suitable for a tractor larger than mine, has "open" draw pins protruding from the harrow frame; in a "normal", undropped position. The Land Pride DH1560/60 has dropped "open" draw pins. Wider Land Pride Disc Harrows have preferred double clevis standard.
The Howse, with its 3" wide, dropped, double clevis is the easiest implement I own to mount on the three point hitch.
Most Disc Harrows provide gang angle adjustment via clamp plates and adjustment holes in the frame. Clamp plate adjustment is simple, strong and inexpensive to manufacture but time consuming to adjust in the field. While the need to change gang angles will vary by user, adjustment is NOT an everyday event for me.
My Howse has five adjustment holes in the frame per gang, some brands have four.
Clamp plate adjustment works via three through bolts/nuts per gang, clamping twinned upper and lower adjustment plates, which have a pair of rib guides on the top plate mirrored by a pair of rib guides on the bottom plate. To adjust one gang angle, the two outer bolts/nuts are loosened with a wrench, the center bolt, which passes through adjustment holes in the frame, is removed, then the gang is pulled and jiggled to line up holes in sliding adjustment plates with alternate holes in harrow frame, using gang length for leverage. The center bolt is replaced and all three bolts/nuts tightened with the wrench. Repeat for the second gang. {Loosening/replacing bolts/nuts is a 15 - 20 minute process.} I have applied wax lube to the harrow frame over which the adjustment plates slide. New, it adjusts easily. I understand with paint abrasion, rust, dust, deformity, etc., gang adjustment becomes harder. However, I will settle on a 'default' gang angle setting soon and only change gang angles occasionally thereafter.
Some TBN threads suggest substituting a 5" pin as a pivot, in lieu of the center bolt. With only a center pin, it seems possible the center support could "jump" the guides under load; stay with the center bolt and nut.
Three Disc Harrows could be accurately described as HEAVY DUTY, by design and by weight. All adjust gang angles more readily than the Howse friction plate system but you pay for that convenience.
Everything Attachment's ETA-XD-BF-DH-16-18 disc harrow weighs 686 pounds (43 pounds/disc) and is priced at $1554 delivered to Fanning Springs, North Florida. The ETA disc has two, long, gang adjustment screws, one on each gang, to adjust the gang angle of attack. I admired ETA disc at the 2012 Sunbelt Ag Expo in Georgia. Leinbach box-frame disc harrows use an identical screw adjustment.
Monroe Tufline's THE71618BF disc harrow (1-1/8" axle) weighs 670 pounds (42 pounds per disc) and was quoted at $2100, plus a local delivery charge. The Tufline claims lever adjustment of the gang angles. I researched the Tufline 'THE' discs on Tufline's very basic web site. I have not seen a Tufline live but the Tufline brand enjoys an excellent reputation.
Brown Manufacturing Corp., Ozark, AL, produces the BDH-600-1620 Disc Harrow (1-1/8 axle), 6'-4" width, 1095 pounds (68 pounds per disc!) with lever gang angle adjustment priced at $2535 FOB factory. I researched Brown's BDH Disc Harrow on Brown Manufacturing´s web site.
Price is not the first priority when I purchase attachments. However, my Florida rock free, sandy-loam is not challenging to disc so I bought the Howse DLHT as adequate and a good value. I paid $950 delivered. (No sales tax in Florida on ag or forestry equipment.)
Pulling a Disc Harrow is high draft force work. Not only is the implement weight being pulled, but the discs are resisting passage through the soil, proportionate to gang angle adjustment. Box frame Disc Harrows require minimum five tractor horsepower per foot of width, plus four-wheel drive for traction. To optimize soil mixing a Disc Harrow must be pulled at a brisk pace.
I pull the Howse behind a Kubota B3300SU tractor/loader. ( 33-hp / 1,900 pounds / 4-WD / 58" tire width ) Tractor and Howse 587- pound Disc Harrow are well paired.
The B3300SU is in HST/MED range pulling the Howse. In repeatedly cut soil, in which the Disc Harrow will sink deep, additional throttle is required to keep the B3300SU from bogging down. Infrequently, I need to lift the Harrow just a tad. Adjusting gang angles to a less aggressive setting will reduce draft force.
Disc Harrows are frequently used to prepare game food plots. For food plot preparation, where you will maneuver between trees and boulders and work on slopes, buy a disc no wider than your tractor's rear tires. Anything wider and the tractor will pass through gaps but the disc will "hang up" and you will waste time extricating tractor+harrow combination, possibly banging up the tractor in the process. It is important to buy a heavy enough Disc Harrow; it is rarely practical to make a second pass over food plot ground.
It is important to tighten the four axle nuts regularly on a new disc harrow; they loosen. If the four axle nuts are tightened regularly the entire gang assembly will settle-in eventually and thereafter axle nuts require tightening infrequently. If axle bolts are not kept tight, disc hubs and axles will work each other, ruining one or both.
A test for tightness involves "ringing" the discs with a mallet when the harrow is elevated. A loose disc will give off a flat tone.
Howse offers its harrows in Kubota orange paint. Thank you, Howse. Standard Howse color is red.
Two complaints: No operator's manual with the Howse. I like manuals. Photo #10: When adjusting the rear gang I found the left clamp bolt to be 4-1/2" long, instead of 5" like the other five clamp/adjusting bolts. Sloppy assembly. So I drove 20 miles/round trip to Tractor Supply for a $3.52, 5" replacement bolt. I have added upper/lower flat washers to six gang angle adjustment bolts to preserve the paint.
HOWSE LINKS 16/18; 16/20:
https://store.howseimplement.com/in...en/disc-harrow-16-18-blades-w-ball-brg-1.html
https://store.howseimplement.com/in...t_en/disc-harrow-16-20-blades-w-ball-brg.html
   / Disc for Kubota M5040 #4
I am looking into buying a disc for my Kubuta M5040. Nice tractor. I be jealous.
Tractor is 4x4 and 50hp with r4 tires
Questions:
I am right in assuming I want a 3pt type disc? YES. Pull Disc Harrows much less maneuverable, harder to transport between plots.
Benefits or concerns with a disc vs a 3pt tiller? Disc more rugged, faster, "enough". Plot seeds are eager germinators.
Will a plow be beneficial before using the disc? Some ground has never been worked, others have been. YES.
But if you have a heavy enough Disc Harrow it will suffice. Plowing a hillside, one tire down in a furrow, is NOT for the inexperienced.
If I need a plow, what size? Spend your money on a Cultipacker, not a plow.
I will someday probably own both a disc and a tiller but right now I can't buy everything. Who can?
Try to give me a size and average cost of a used disc. Howse is pretty cheap NEW.
I know that's a lot of reading and many questions. We volunteer here to help.
   / Disc for Kubota M5040 #5
. . . Pull Disc Harrows much less maneuverable, harder to transport between plots. . . .
The part about being harder to transport only applies to the drag type, not the pull-type ones that have gauge wheels and tires on a rockshaft that raises and lowers the tires. The latter type is easy to transport between plots and are typically heavier and, therefore, plow better. That type, however, is less maneuverable than a 3 point mounted one.
   / Disc for Kubota M5040 #6
Depending on whether you already have the other -non disc attachments...
After buying a used tandem 20 disc harrow- 10 round and 10 notched - and even with weighting the disc, I was unable to break up some of our fields.
decided to get something to open the field up- a JD 3 bottom plow and repaired a free broken tiller I had been using for 3 point weight.
If you have fallow , tough soils- may not be able to disc the field to satisfaction... Which is what happened to me.
If the soil has been turned in the last few years, then you may be fine with just a disc.
If just starting out and I could only have one of the 3 (plow, disc or tiller) It would be a tiller because it can work even a field that hasn't been touched in 30 years into powder if necessary- as long as the tractor has low enough gears and enough pto power. Pretty sure the Kubota M5040 is more than capable.
If you are going to have all 3 then I would try the disc first- if it won't begin to turn the soil in 2 passes, I would switch to the 3 point plow and then go back to the disc, or you can till and then disc if you want. In tight or small areas the tiller is VERY hard to beat and you can always till or disc once the surface has been opened up. I haven't owned a cultipacker , but they sound like they would be very handy...
not sure if this helps
Good Luck
As for as the discs -Jeff had lots of good information -and I am sure there are other TBNers with all of the field implements and more experience than me, hopefully more people will jump in with some more information...
Thanks for the help guys. I appreciate the advice and knowledge you have shared. Do you think a 3pt disc about 6'-7' would be ample? What if I disced the ground with that after I plowed the ground? I am looking at a few Used discs that have 16" discs. I'm still trying to figure this all out. Sometimes the more I read and think, the more confused I get! I love the idea of a brand new 6' landpride tiller from a local dealer but the cost is high. I'm sure it's worth the money, but right now it's just not smart for me and my family. Anymore thoughts or recommendations? Thanks again!
   / Disc for Kubota M5040 #8
I have a 4900 that I use for food plots. I disc up about 7-8 acres per year.
I have a 3 point 6.5' Monroe-tufline with 22" discs that weighs 850 pounds. It does pretty good but it isn't enough weight to cut through sod. It takes 4-5 passes. If I had to do it again I would get a 8' pull behind and a rotary tiller.
   / Disc for Kubota M5040 #9
I have a Kubota L5740 and I have a 6' disc and a 6' tiller.
I use both for my business, and for food plots. We plant about 20 acres of food plots per year on my deer lease.
I would NEVER use the tiller on our food plots. In my opinion, the tiller will do a good job, but it is a much higher maintenance attachment. And, we have some stumps in our food plots that would destroy my tiller if I hit them. I would think that if you have rocks or stumps in your food plots, they could destroy a tiller too. My tiller is used to prepare athletic fields for renovation.
The soil on our food plots is fairly sandy, so the disc does a good enough job. And, we till/plant every year, so the soil has been worked every year for the past 5 years. On new plots that have not been tilled in a few years, you would probably need to disc it 4-6 times to get it into shape.
I would suggest spraying food plots with Roundup herbicide at least 4-6 weeks before you plan to disc them and they will work up a lot easier.
   / Disc for Kubota M5040 #10
LeadPoison: I have a 3 point 6.5' Monroe-tufline with 22" discs that weighs 850 pounds. I disc up 7-8 acres per year.
Notched discs or smooth discs on that Beast?
I keep asking T-B-N participants how the lever adjustment of gang angles works on Tufline discs so I can make Post #3 more informative and accurate. No replies of yet.
How about some comment? How about pictures of the lever adjust mechanism, when you have time?
I JUST COMPLETED A GOOGLE SEARCH OF T-B-N ARCHIVES. THERE IS NOTHING ON LEVER ADJUSTMENT OF GANG ANGLES ON TUFLINE DISC HARROWS.
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
RIGID TOOLBOX (A50854)
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2011 FORD F-250 (INOPERABLE) (A50854)
2011 FORD F-250...
