Disc Brakes, which pad should wear faster, inboard or outboard?
   / Disc Brakes, which pad should wear faster, inboard or outboard? #1
QueBota
People's Republik of Maryland
B2910
IYHO, which pad typically wears more quickly, inboard (piston side) or outboard. Having a debate with my son.
He has his theory, I have mine.
I suppose in the ideal world they should both wear evenly, in my experience that hasn't been the case.
Would love to hear the TBN opinion on this issue. There is a 12 pack of micro brew riding on the answer.
We are talking older American vehicles, single piston calipers.
Thanks,
Q
   / Disc Brakes, which pad should wear faster, inboard or outboard? #2
Inboard in my experience.
   / Disc Brakes, which pad should wear faster, inboard or outboard? #3
Outboard in my experience. Seems they never truly uncontact themselves from the disc.
Chris
   / Disc Brakes, which pad should wear faster, inboard or outboard? #4
Another vote for inboard.
   / Disc Brakes, which pad should wear faster, inboard or outboard? #5
I'm going to say for must of our big trucks they actually wear quite evenly. But can't really say which side wore more. Can change every time you change pads. I would vote for inboard by the cylinder
   / Disc Brakes, which pad should wear faster, inboard or outboard? #6
Inboard every time as far as I have seen. Which figures since it is much harder to check...
   / Disc Brakes, which pad should wear faster, inboard or outboard? #7
Inboard on the rear discs, fairly even wear on the front discs.
Thanks guys, we always change them both when servicing.
Any theory behind which bad wears more would be appreciated.
I'm an inboard guy, piston applies pad directly to disc with more force. Outboard pad is just pulled in from the outside. Granted the inboard pad is retracted from the disc when the piston moves back in and although the outboard pad spends more/most of its time in contact with the disc, it is "just along for the ride".
I've seen outboard wear more when the slides/pins were dry or in a bind.
Q
   / Disc Brakes, which pad should wear faster, inboard or outboard? #9
If the inboard wears more, its a sign the puck in the disc is a little sticky, the outboard its a sign the sliders are sticky. Of course there are discs with pucks on both sides, it all depends on the style. But I've seen even wear but seem to see the inboard wears more.
   / Disc Brakes, which pad should wear faster, inboard or outboard? #10
'83 s10 with single piston - both even
'02 1500 with dual piston (inside) - both even
The few times they haven't been even I've been able to figure out what was sticking/jammed and causing one side to wear faster than the other.
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2025 New/Unused Wolverine 32in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
John Deere 5400 Tractor with Loader (A51573)
John Deere 5400...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
