mmsb27
- Joined
- Apr 1, 2012
- Messages
- 43
- Location
- PA
- Tractor
- Kioti Mechron 2200PS Ford 340 b, Farmtrac 550 DTC
Hi. I recently bought a used CountyLine (Tractor Supply) 7 foot Three point hitch disc. Three of of the disc plates were broken, so I removed the axle nut and jam nut off of two axles, and replaced them. I used my Rigid 18 volt impact gun, to tighten the 1 7/16” nuts on. I don’t have experience using a disc, let alone working on one. So…. How tight should I have made there nuts. Is it possible to have them too tight? I used the middle setting on my impact gun. Another question, does tightening affect the spinning of the axles? Any pointers on how I would know when a bearing carrier would need replaced, since this disc set has non greasable axle bearings. I had to use the impact gun to get the nuts off to replace the broken discs. Any other pointers and suggestions are appreciated. Thank you
