Price Check Disappointed in L3010HST! What price for L3710HST
   / Disappointed in L3010HST! What price for L3710HST #1
shadow
Wheeling, WV
L3710 HST
Disappointed in the L3010HST. What is a good price for a L3710HST?
Today I visited a local Kubota Dealer and test drove a L3010HST.
I was very disappointed in the power of this machine. I have
read several posting on various forums stating how great this tractor is, but
I believe it is lacking power. It was riding on unloaded R4 tires with a front loader on
it. The tractor barely had the power to pull itself up a steep hill in 2nd range, I had to let up on
the hydostatic pedal and creep over the top to make it up. I would hate to see what it would
do if it was pulling a load or if it was powering a mower behind it. It also was lacking power in 3rd range on flat ground,
It seemed like it might be able to reach full speed/full RPM's but it was sluggish and I
ran out of space to fully test it. I was wanting to test an L3410HST to see if
it could do any better, but the dealer didnt have one. He had a L3710GST with unloaded turf tires and a front loader so
I thought I would give it a try. What a difference! It pulled the same hill in 5th gear with no problem. I also did excellent
on flat ground in 7th gear. The test course was to rough to try 8th, but I'd bet it would have done well.
My conparison between these two tractors wasn't completely fair. The L3010HST was equipped with the taller R4 tires VS the turf tires on
the L3710. The L3710 also had a glide shift transmission. The L3710GST didn't even breathe heavy in any of my tests, even taking
off in 7th gear at 2100 RPM and it wasn't at it's rated RPM for full power (2600RPM).
Does anyone out there have a L3710HST?
Does it perform well? Does it take off quickly or do you have to ease it up to full speed in 3rd range.
Does it have plenty of power for pulling itself as well a powering implements? Especially pulling hills.
Does it pull steep hills in 2nd range with no problem?
Im am trying to find a L3710HST with R4's at another dealer try to find this out for myself,
but inventories seem to be low this time of year.
Am I expecting to much out of the L3010HST?
I priced the L3710HST with Loaded (W/Washer Solvent) rear tires, LA682 loader, R4 industrial tires, and foldable Rops
I was quoted $20,400.00 which included a $500.00 rebate from Kubota. Is this a good price?
Does anyone have any inside scoop on whether Kubota will offer this rebate or a better one later this year to
close out the 2001 Models?
   / Disappointed in L3010HST! What price for L3710HST #2
I have one question, shadow. Are you familiar with hydrostatic transmission operation? If so, then please ignore this because I have no intention of being condescending and the 3010 you drove may have had a problem, or simply not be what you need. However, if you're not familiar with an HST transmission, you may have made the same mistake a lot of us (maybe most of us) made to start with. You set the engine rpm with the throttle, but there is a natural tendency to think of that hydro pedal as an "accelerator" when in fact you have to think of it as a gear shifter. The farther down you press it, the less power you have, but the more speed (as in shifting to a higher gear). If the tractor starts to slow down, it seems to be natural to push farther down on the pedal, when in fact you need to ease up on the pedal (or increase rpm with the throttle; not the hydro pedal). Like I said, if you already knew this, then ignore this message. And good luck with your shopping.
Bird
   / Disappointed in L3010HST! What price for L3710HST #3
Shadow,I'm curious about the 500. rebate that you mention.Is this rebate good on all Kubota models? Is the rebate just on specific models? Do you know what kind of time frame the rebate runs? Thanks for any info,Mike.
   / Disappointed in L3010HST! What price for L3710HST #4
Bird,
I made the same observation today test driving a Kubota B7500 and a TC25D. Climbing a small hill, I felt the urge to hit the accelerator a bit but found the tractor slowing. Once I backed off the pedal, I pulled a small hill with no difficulty.
   / Disappointed in L3010HST! What price for L3710HST #5
Like Bird said, the pedal is not an accelerator. I still have to remind myself to let up on the pedal for more power. But once I do, nothing stops me. I have had the bucket filled with granite rocks going up a steep hill in mid with not a hesitation as long as I remember to stay light on the pedal. David
   / Disappointed in L3010HST! What price for L3710HST #6
shadow: re-read birds post, he said all i would say but better!. hydros are a different breed and take a bit of time to get used to.
Mike,
As far as I know the rebate from Kubota was just on the L-series tractors
   / Disappointed in L3010HST! What price for L3710HST #8
I borrowed a neighbors L3710HST a few weeks ago and found I could drag down the RPMs very easily in M and H range. It was so bad I wondered if the govorner was broken.
   / Disappointed in L3010HST! What price for L3710HST #9
I have been quite happy with my L3710HST. 66 hours on it since I bought it new in February. Bird's post says it all re: hydro.
Andy in NH
   / Disappointed in L3010HST! What price for L3710HST #10
Again to restate Birds remarks, you need to learn the operating characteristics of a hydrostatic transmission, especially if your not familiar with them. Go try a gear drive to get the idea of how much power the engine is capable of. That is close to what a hydrostatic is capable of, it just takes some understanding how it operates. I drove a Bobcat for awhile which is a hydrostatic drive, it seemed terrible to me at first until I learned how to use it. The speed I could get things done was incredible when compared to anything with gears. RPM's are critical for the hydrostatic to operate with satisfactory results. In the M range, make sure you have the RPM's to go full pedal. H is pretty much transport speed, don't go draggin a box blade or even try to run up hills with it, you simply will need more power then what these compacts are designed for. Heck, even the articulating 960 series loader CAT makes have this same problem, try to move a 4 yd bucket into some soft dirt in high and forget it, they don't have that kind of power. Rat...
   / Disappointed in L3010HST! What price for L3710HST #11
I think I've got the hydro operation down OK - been using one for 4 years now.
The thing I noticed on the 3710 I used is that the engine RPM would vary by 500+ RPM just driving the machine around on flat ground without pushing or pulling anything. Just transporting the tractor. My 2910, on the other hand, holds the RPM within 100, maybe 200 RPM across a wide range of loads, only dropping below the set point when completely overloaded. I brought this up in another thread, so I applogize for repeating, but it relates to this topic too. Granted, the 3710 is a good bit heavier than a 2910 and is geared to move faster in H range, but it still seemed like the governor was challenged to hold constant RPM.
For others with the Grand L's, what RPM variation do you find and at what point does theengine become overloaded and RPMs drop below the set point?
   / Disappointed in L3010HST! What price for L3710HST #12
hayden
I run the L4610 about 1800/1900 rpm's and M range for just about everything. I'm not noticing the bogging mentioned above.This includes a lot of FEL work digging dirt, etc. As you mentioned the only time it drops is when completely overload is for example digging into a hillside when there's no more room in the bucket.
regards
Mutt
   / Disappointed in L3010HST! What price for L3710HST #13
Hayden, I know of no governor on the Kubota diesels. The fuel injection pump supplies varying amounts of fuel depending on throttle position, after that the only way to over rev a diesel is going downhill while in gear, particularly in a low gear. It leads me to believe that something unusual was going on with the engine, perhaps as a result of the hydrostatic. I can see that my comment about hydro's was not necessary for you, but perhaps other's looking at this post will learn something, Rat...
   / Disappointed in L3010HST! What price for L3710HST #14
I am about to by a 3010. Is the 500 from the dealer or direct from Kubota? Anyone else know about this?
   / Disappointed in L3010HST! What price for L3710HST #15
hayden,
I've taken my 3710hst on the road a few times for distances of about 3-5 miles. What I found is that it's sensitive to gradient and you really have to feather the HST pedal to keep the revs constant when in high. So basically you can keep your speed constant or your revs but not both when going up hills, etc.
I didn't notice how much variation I had, because I was deliberately trying to keep the revs constant.
Joe
(4) UNUSED FORERUNNER 12-16.5 SKID STEER TIRES (A60430)
(4) UNUSED...
HOMEMADE 64"X14' DOUBLE AXLE TRAILER (A60430)
HOMEMADE 64"X14'...
2019 CATERPILLAR 289D SKID STEER (A60429)
2019 CATERPILLAR...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
