Disadvantage Of Aluminum Trailer?
   / Disadvantage Of Aluminum Trailer? #1
Utopia Texas
Platinum Member
Brookshire & Cat Spring,Texas
Kubota B2650 / Kubota L6060 / Kubota ZD2300
Comparing a flat bed aluminum trailer to a similar weight range in steel with wood deck are there any disadvantages to the aluminum trailer? I have the opportunity to buy a very good used aluminum unit and I am very tempted. No wood deck maintenance...?
   / Disadvantage Of Aluminum Trailer? #2
I can't nail or screw anything to the floor, but there is usually a work around for that.
When I haul my tiller I lay a 2x5 foot piece of plywood under it to protect the floor. Without it, the tiller really gouges up the floor with even a short 20 mile trip. I seen a guy once that put plywood or car tires under everything he hauled to a swap-meet on his new trailer.
If the new ever wears off I will quit using the plywood. But it has been 3 years now and still looks new.
   / Disadvantage Of Aluminum Trailer? #3
If it's a good trailer you better grab it before someone else does. Used AL trailers are not plentiful and normally priced close to new.
   / Disadvantage Of Aluminum Trailer? #4
Personally I'd be going for the steel one. Aluminum is more prone to fatigue cracking, it'll more than likely break before it bends, at least steel you'll have a bit more warning, you have to be careful about corrosion, harder to repair should it break.
Before anyone says there are 45' aluminum road trailers out there, yes I know, you asked for opinions :)....Mike
   / Disadvantage Of Aluminum Trailer? #5
Ya the are always broke some where . Not worth the trouble of welding on them all the time .
Sent from my iPhone 5 using TractorByNet
   / Disadvantage Of Aluminum Trailer? #6
Main disadvantages have been stated - expensive and harder to repair. But if you need the weight savings, there is no substitute.
   / Disadvantage Of Aluminum Trailer? #7
I have a steel trailer and a aluminum trailer. Both have advantages.
I personally like wood decks vs steel or aluminum no matter what the trailer is made of. Just too slick in my opinion.
Chris
CAT 973 (A47384)
CAT 973 (A47384)
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
JOHN DEERE 7210R LOT NUMBER 264 (A53084)
JOHN DEERE 7210R...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
SCHAFFER 2430SLT LOT NUMBER 150 (A53084)
SCHAFFER 2430SLT...
