Dirt Scoop Users - Don’t Do What I Did!
   / Dirt Scoop Users - Don’t Do What I Did! #11
Re: Dirt Scoop Users - Don?t Do What I Did!
Thanks for the advice. I have never tried reversing the scoop as I have my Freedom Hitch attachment connected to the opposite end. I have had the same problems with dumping mechanism but will try the suggestion of lowering scoop before trying to release the latch. There must be some sort of latch mechanism that would work better than the current system. Maybe someone has already discussed the "fix" in an earlier discussion.
Lyle
   / Dirt Scoop Users - Don’t Do What I Did! #12
I bolted about 18 inches of an old stabilizer arm (1/4" x maybe 2-1/2" steel) to the trip lever of my scoop. I can reach the handle from the seat when the scoop is mounted to the rear, or put a rope on and get lots of leverage the other way. Still not perfect dumping, but lots better.
   / Dirt Scoop Users - Don’t Do What I Did! #13
Jerry
A good lesson in your post for all of us. Loose and excessive rope can be a real "pain" at times.
Thanks for sharing and hope your hand is OK now??
Cheers
2014 REITNOUER MAXIMISER 48' FLATBED TRAILER (A58018)
2014 REITNOUER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
202474 (A54757)
202474 (A54757)
VICOR HAY CUTTER (A58214)
VICOR HAY CUTTER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2006 Grove TMS900E Quad Axle 90 Ton 5 Mast Telescopic All-Terrain Crane Truck (A55973)
2006 Grove TMS900E...
