Dirt Pile vs. 4120
   / Dirt Pile vs. 4120 #1
om21braz
Veteran Member
Lexington, NC
Was going to do a little filling in some low spots in the yard today. It was a little warmer than it had been and sunny. Placed the tractor in 4WD, lowered/leveled bucket and proceeded into the pile. The tractor comes to a dead stop, then front end raises a little. Tried again, Oops! Frozen dirt pile! The dirt won today, but there's always tomorrow LOL.
   / Dirt Pile vs. 4120 #2
hose frozen dirt piles are sure hard to dig into. Where did you attempt to scoop? At ground level? half way up? Having a slight tilt to the bucket and going in about at ground level will pry your bucket in and you can loosen up the soil. Its worth a good try. :)
   / Dirt Pile vs. 4120 #3
Yep its that time of year :( weather station saying warming up for you folks down there,but mother nature decides to thaw or not to thaw. ;)
I attempted about as you note ground level/slight tilt on bucket. It just wanted to push bucket up the side of the pile. A toothbar would probably make a big difference. If I attempt again soon, swapping out to the pallet forks to loosen things up a bit might help to start?
2018 Ford Fusion Sedan (A53424)
2018 Ford Fusion...
2025 Unused LandHero LDH-T460XX Ride-On Mini Skid Steer (A52377)
2025 Unused...
UNUSED 3 STEP - STEP LADDER (A54757)
UNUSED 3 STEP -...
Deer Gates (A53424)
Deer Gates (A53424)
UNUSED SWICT 60" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 60"...
