Directional valve with counterbalace valve ?
   / Directional valve with counterbalace valve ? #1
hodinhtran
Good day sir.
I have the two stage directional valve (upper stage valve is float type. Lower stage valve is tandem type). I use this valve (consist of upper and lower stage) with fix displacement pump for liftting load without counterbalace valve (or brake valve). So Motor overruned and load go down fast. Can I insert some valves (I don稚 know excatly what kind of valve) between the upper stage and lower stage to have the directional valve with function counterbalace valve for prevent load from falling down fast. Thank for your help.
   / Directional valve with counterbalace valve ? #2
When I worked on fork lifts there is a flow control valve on the bottom of the mast. The carriage can go up as fast as the spool movement allows but when you move the spool to lower the load it will only descend as fast as the flow control will allow. Install this concept in your system.
Craig Clayton
   / Directional valve with counterbalace valve ? #4
   / Directional valve with counterbalace valve ? #5
That was my immediate idea too, a one way adjustable flow restrictor...
Just remember that drop speed will depend on load weight...No load weight and it might be very slow down....
Also,I did not really figure what valve setup ("upper and lower stage"??) you have for the hydraulic motor.....If you have a 3 position valve (with float in neutral, and power both up and down), you can "push" down, to increase speed when there is no load weight. If so, make sure the motor can handle pressure on both port at the same time. That would be bad for the shaft seal, if there is no case drain on the motor...
   / Directional valve with counterbalace valve ? #6
You can install a counterbalance stack module between your two stage valve and its sub-plate. Sun Hydraulics is the leading manufacturer of these valve stacks.
These will allow you to operate at full speed and still prevent free-fall.
Roy
   / Directional valve with counterbalace valve ? #7
Roy look at my profile and see if you might know me.
2024 Honda Foreman 4x4 ATV (A51694)
2024 Honda Foreman...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2007 Nissan Armada SUV (A51694)
2007 Nissan Armada...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
