Direct Throttle Control?
/ Direct Throttle Control? #1
kdlklm
Saskatchewan, Canada
Kubota BX1830
I'm looking at a small engine to put in a machine that I'm building. I was looking at the Vanguard 37 hp EFI. On the options page it says that Direct Throttle Control is an option. How would that differ from a regular throttle body that comes on the motor. I can't seem to get a definitive answer.
Vanguard™ 37. Gross HP* EFI - Engines - Vanguard Engines
/ Direct Throttle Control? #2
The only thing I can think of is that the "indirect" control may have some sort of governor to regulate throttle, so the user doesn't actually control it, sort of like on a generator
/ Direct Throttle Control? #3
I believe Direct throttle control means it will accept a mechanical linkage to control the throttle. Many EFI engines have a electronic throttle that is simply a electronic rheostat
That's what I was kinda hoping that it was an electronic throttle control. Because the machine that it's going on will be controlled through a joystick. And the throttle would have to be controlled with an actuator if it were manual.
500-gallon Fuel Tank & Pump (A66408)
500-gallon Fuel...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
Wolverine Quick Attach Brush Cutter (A66408)
Wolverine Quick...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
Stout Brush Grapple HD72-4 (A66285)
Stout Brush...
