Direct Throttle Control?
/ Direct Throttle Control? #1
kdlklm
Saskatchewan, Canada
Kubota BX1830
I'm looking at a small engine to put in a machine that I'm building. I was looking at the Vanguard 37 hp EFI. On the options page it says that Direct Throttle Control is an option. How would that differ from a regular throttle body that comes on the motor. I can't seem to get a definitive answer.
Vanguard™ 37. Gross HP* EFI - Engines - Vanguard Engines
/ Direct Throttle Control? #2
The only thing I can think of is that the "indirect" control may have some sort of governor to regulate throttle, so the user doesn't actually control it, sort of like on a generator
/ Direct Throttle Control? #3
I believe Direct throttle control means it will accept a mechanical linkage to control the throttle. Many EFI engines have a electronic throttle that is simply a electronic rheostat
That's what I was kinda hoping that it was an electronic throttle control. Because the machine that it's going on will be controlled through a joystick. And the throttle would have to be controlled with an actuator if it were manual.
New/Unused Landhonor8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Dragline Bucket (A65640)
Dragline Bucket...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2013 KENWORTH T6 SERIES (INOPERABLE) (A65643)
2013 KENWORTH T6...
Jack Daniels Metal Sign (A65583)
Jack Daniels Metal...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
