DimmingOutdoor Lights
   / DimmingOutdoor Lights #1
Dennisfly
Lake Anna, Virginia and Alleghany County, VA
John Deere 4410
My wife just bought two outside light fixtures that she wants me to use to replace two old ones. They are motion activated, have a bright and dim mode, and a sensor to only illuminate when it is dark out. So as I understand it, depending on how you set it it, it will come on dim at dark, go to bright when motion is detected, and reset to dim after a period of time. It states on the package that you must use an incandescent bulb and not a CFL. I called the manufacturer and asked if a dimmable CFL or LED bulb is acceptable. The lady I talked to said that she thought a dimmable CFL would work but not an LED. She didn't seem too sure of her answer!
Does anyone have knowledge or experience in this regard that they could share?
   / DimmingOutdoor Lights #2
find out the method of dimming.
i'd guess it's a generic triac circuit.
once you find that out.. find a bulb that is compatible with that dimmer technology. many older ballasts do NOT like it.
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
WHISPERWATT DIESEL POWERED GENERATOR (A53843)
WHISPERWATT DIESEL...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
