Dimension or picture from 425 owner
   / Dimension or picture from 425 owner #1
bullitt
Pittsburgh PA
pt422
Hello everybody,
I am preparing to put a Kohler 27 hp engine into my 422. The deisel option ended up being very expensive ($5k+) and is therefore beyond my budget and not very cost effective when compared to the 1430.
The Kohler drawings are less than complete. If I could get some approximate dimensions, it would help check my work before I have the 422 apart and discover a dimensional boo-boo.
As a check of my dimensions, the following off a 425 would be helpful:
1. A picture of the front lovejoy coupling between the screen over the flywheel and the vertical portion of the engine cradle.
2. The approximate dimension between the screen and the vertical portion of the engine cradle.
3. Or the dimenstion between the vertical portion of the engine cradle and the vertical face of the forward part of the lovejoy coupling where it goes from a small diameter to a large diameter. This is a critical dimension, but I suspect this may not be visible as it looks like it will be behind the screen.
The Robin engine is destined to become a 10 or 12kW generator.
Thanks in Advance
bullitt
   / Dimension or picture from 425 owner #2
if you saw my post about the new 425 you may decide to go an other direction,the wheel motors may give you the power you are looking for? i also did some research in to a smaller wheel tire combination with a 21" high tire vs.23 high tire. now that will give very substantial increase in power.i live in blairsville pa. if you need help with any thing.
UNUSED PABREAK METAL COYOTE SHOOTING TARGET (A57193)
UNUSED PABREAK...
2016 Chevrolet Malibu Sedan (A53424)
2016 Chevrolet...
(2) 5' FOLD UP TRAILER RAMPS (A57192)
(2) 5' FOLD UP...
2007 Freightliner M2 106 Medium Duty Pac-Man RL10 10 Yard Refuse Garbage Truck (A55852)
2007 Freightliner...
Uni-Carriers S1S1L15NV 3,000lb Electric Forklift (A55851)
Uni-Carriers...
John Deere 7410 (A53317)
John Deere 7410...
