Diging Drainage Trench With My CK30HST?
   / Diging Drainage Trench With My CK30HST? #1
Texas Kioti
Hockley, TX
2012 CK30HST
Hello all...question...What would be the easiest way to dig a small ditch to drain a field with the equipment that I have now. I'm talking no more than 6" deep by maybe 40'.
FEL, box blade jacked on a slight angle???? My angle blade is 5 hours away at the moment or I would use that.
Thank in advance
   / Diging Drainage Trench With My CK30HST? #2
Either will do the trick. If you want to slope the sides, first dig it down a bit with the fel and then use the box blade with the tire in the newly formed slot. Sometimes it helps to lower a couple of scarifiers. I dig out and install culverts using just the fel regularly.
I forgot to mention that I also have a tooth bar on my FEL bucket if that helps with suggestions.
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
2018 Kia Optima Sedan (A55973)
2018 Kia Optima...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
