Diging Drainage Trench With My CK30HST?
   / Diging Drainage Trench With My CK30HST? #1
Texas Kioti
Hockley, TX
2012 CK30HST
Hello all...question...What would be the easiest way to dig a small ditch to drain a field with the equipment that I have now. I'm talking no more than 6" deep by maybe 40'.
FEL, box blade jacked on a slight angle???? My angle blade is 5 hours away at the moment or I would use that.
Thank in advance
   / Diging Drainage Trench With My CK30HST? #2
Either will do the trick. If you want to slope the sides, first dig it down a bit with the fel and then use the box blade with the tire in the newly formed slot. Sometimes it helps to lower a couple of scarifiers. I dig out and install culverts using just the fel regularly.
I forgot to mention that I also have a tooth bar on my FEL bucket if that helps with suggestions.
2007 FORD F-450 SUPER DUTY (A52472)
2007 FORD F-450...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
20711 (A50323)
20711 (A50323)
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2020 TAKEUCHI TL 12V-2 (A52472)
2020 TAKEUCHI TL...
