Digging with Bobcat S150
/ Digging with Bobcat S150 #1
TimberHole
Platinum Member
Missouri
JD9504WD w/ 75 Loader, JD345, Bobcat S150
I have a Bobcat S150. I just put a set of over the tire steel tracks on it. I have some bottom ground with dikes and thought the tracks would make it a reasonably capable machine in the bottoms. I need to repair some small dikes damaged from flooding. Is this machine capable of digging if I get a tooth bucket? Right now I only have a smooth bucket and it痴 not good for anything except skinning off a bit of vegetation. I probably do not need to keep this machine if it won稚 do this repair work.
/ Digging with Bobcat S150 #2
Yes a tooth bucket will help considerably, nothing like a heavier wheeled or tracked machine will but the S150 will certainly get a good amount of work done with a tooth bucket.
/ Digging with Bobcat S150 #3
The toothed bucket works good in the clay here:
/ Digging with Bobcat S150 #4
No but I've buried a horse with my LS tractor FEL.
Does that count? LOL
Remembering the encounter with my neighbor in melt down mode.
Things that people with tractor get ourselves in to that have no back door.
Just dig the hole.
The deeper the hole the longer the ramp.
Pretty simple in north Florida sand/Gray sticky clay.
Update: I figured out my bucket was the original Bobcat bucket and has holes for teeth. I bought teeth from Bobcat. With the steel tracks and teeth I can fill the bucket with that hard clay. I made a couple of dike repairs yesterday. Very impressed with this setup and I think it will do everything I need it to.
/ Digging with Bobcat S150 #6
Glad you figured it out. :thumbsup: I should have mentioned I bought the teeth from a Bobcat dealer and bolted them on the bucket.
2016 Chrysler Town and Country Van (A61574)
2016 Chrysler Town...
2013 FORD F250 (A60460)
2013 FORD F250...
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63118)
2020 Takeuchi...
2020 INTERNATIONAL LT625 6X4 TANDEM SLEEPER TRUCK (A59910)
2020 INTERNATIONAL...
2020 John Deere R4045 Sprayer (A63109)
2020 John Deere...
