Digging up gas lines
/ Digging up gas lines #31
///I'm sure going to tell you that you won't have a fire or explosion, I don't think you will.///
Thanks Bird, I think I got the gist of your thoughts: don't bother with a "sniffer" just go ahead 'cause you practically guarantee it is safe. Thanks, I feel better now that I feel justified in using a torch.
Actually, since they left one end 3-4 ft in the air when they backfilled their trench just so I could pull it, I could fill it with water. Even if it doesn't fill completely along the entire length, the part I'm cutting will be filled. Somehow I'm not sure this is a job for my lil Kubby. Maybe my 4x4 Dodge turbo diesel in low range or the 12,000 lb winch doubled to 24,000 with a snatch block. Need to figure a way to keep the truck from going to the pipe instead of the other way 'round.
I wonder about how much lateral force applied at bumber level a Mark I Mod I standard issue wooden power pole can handle without causing problems??????? How about at ground level?
Patrick
/ Digging up gas lines #32
<font color=blue>I wonder about how much lateral force applied at bumber level a Mark I Mod I standard issue wooden power pole can handle without causing problems??????? How about at ground level?</font color=blue>
I would use a "deadman", bury a 6 ft log lengthwise about 6 ft in the ground with a chain attached. It is a bit of work, but easier than dodging downed power lines and explaining what happened to the electric company.
/ Digging up gas lines #33
Ed, How much dynamite do you suppose it would take to make a hole six ft deep and six feet wide in heavy moist clay?
Patrick
/ Digging up gas lines #34
I think Ed's idea has merit. In my neck of the woods if you snap, or damage a utility pole, a ball park figure of $1,500 is quoted. That could buy new equipment for the tractor./w3tcompact/icons/cool.gif
I have used a deadman with good results, but we only put it down a couple of feet. We only made the trench a little wider than the log. You want to dig a T shaped trench and run your cable in the vertical part of the T, so the force won't pull it out of the trench. Good luck patrick!
/ Digging up gas lines #35
<font color=blue>Ed, How much dynamite do you suppose it would take to make a hole six ft deep and six feet wide in heavy moist clay?</font color=blue>
I take it you don't have a backhoe.
You don't have to go 6 foot deep with a 6 foot log, that's just how deadman was defined to me while I was in the Marines. You could probably go with a 3 foot log 6 inches in diameter, buried 3 feet deep. You might even try driving some long pipe or drill rod into the ground, use a couple for anchor points. Or maybe a couple of those screw in anchors the electric company uses to brace the poles.
When we dig graves, we can usually go 3 feet wide by 7 feet long by 5 1/2 feet deep in about 3 to 4 hours, unless we hit rock. And yes, that is digging by hand.
/ Digging up gas lines #36
Why would you dig a grave by hand?
/ Digging up gas lines #37
<font color=blue>Why would you dig a grave by hand? </font color=blue>
Trust me, its not by choice. It is and old country cemetary, and there are places you can't get in with a backhoe. We can't dig at all in the oldest section, as we don't have a map marking the individual graves. Even on the mapped section, we sometimes come close to other vaults. The head stones are so close in places where I barely have room to get a quad in to haul the excess dirt out.
/ Digging up gas lines #38
You may find that surface area firction is a dit hight for that pipe, but you never know.
An idea to make it possibly less explosion prone would be to take an old towel, wet it, and wrap it into a ball, and tie with twine... make it just a bit bigger than the pipe ID.. use it as a plug, and just push it into the pipe with a shovel handle or similar device... push it just past the place you are cutting, it should provide a decent seal to isolate the section you are cuting from the rest of the pipe... add water to keep the plug expanded, etc.
Soundguy
/ Digging up gas lines #39
<font color=blue>You may find that surface area firction is a dit hight for that pipe, but you never know</font color=blue>
Soundguy, I think that your keyboard might have been broken when you typed this one??/w3tcompact/icons/smile.gif
/ Digging up gas lines #40
Good grief!... I don't understand it. I've seen this happen a few times now. I still had this page saved in my browsers 'back feature', and those spelling mistakes arent there! I find this very odd. Problems in posting?
Soundguy
""You may find that surface area firction is a dit hight for that pipe, but you never know
Soundguy, I think that your keyboard might have been broken when you typed this one?? ""
2017 Ford F-150 Crew Cab Pickup Truck (A59230)
2017 Ford F-150...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2014 FORD F-350 SERVICE VAN (A62130)
2014 FORD F-350...
2022 Transcend Xplor 245RL 30ft. T/A Travel Trailer (A59231)
2022 Transcend...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
