digging tree planting holes?
   / digging tree planting holes? #1
evofxdwg
middle GA USA
Yanmar 1610D
Its time to put out some small trees. I have a 1610D with Koyker 80 FEL and box blade. Any tricks or recommendations for adding an implement to dig holes to plant 4 to 6 ft tall balled seedlings without tearing up a big place in the yard? All i can think of is adding a posthole digger and augering out several closly spaced holes, then shoveling it out by hand. Is there a narrow, offset down, bucket i can bolt on in place of Koyker 80 bucket to use for digging?
   / digging tree planting holes? #2
I saw where a guy had bolted a backhoe bucket to his FEL in order to dig small holes. As far as I know there is no manufactured type device like you descibe.
   / digging tree planting holes? #3
You can get larger augers for a post hole digger. I just don't know if a 1610 is man enough to use them. I have a friend with a Bobcat that uses a post hole digger and a 30" auger to plant trees. Pretty slick. I used my auger with a 6" bit to dig a square hole as you descibe. It really wasn't that bad for just the one. Most rental places have small trackhoes or backhoes. It would probably be cheaper than buying a lot of equipment , and fun to use something different.
   / digging tree planting holes? #4
I have seen and watched a gent use a small bucket adapted to his FEL arms. As there is no side to side movement on the loader, it became quite a chore to constantly move in and out to dump the small amount of dirt off to one side. It was not very pratical.
I think the auger is the way to go, especially if you only have a few trees to plant.
Mark
   / digging tree planting holes? #5
I had a commercial apple orchard for over twenty five years in the Rio Grande Valley of central New Mexico and planted many trees by hand with a shovel. What a lot of work. We moved here to West Central Texas about a year ago. I am now planting apple trees using my 9 inch post hole digger.
The land I am using has never had as much as a hoe used on it and the ground was hard. I simply dig down about 3 or so feet with the post hole digger and make one hole as close to the other one as I can and put about 7 or 8 holes in a tight circle, pulling most of the dirt out. It really tears up the ground in this circle. Then, we have been putting in a lot of wet shredded paper, mulch and some peat (never any kind of fertilizer) and then covering the hole back up. We let that sit for a few weeks and then simply pull dirt out again with either a shovel or the post hole digger and plant the trees.
This has made planting trees easy for me...as I have gotten a lot older since I put in my orchard twenty five years ago...
I was also surprised at how loose the soil had become, how rich it looked and how the wet shredded paper had began to dissolve and become fertile matter...
Flattman
   / digging tree planting holes? #6
I used a 12" auger. I know your suppose to dig a 3 ft wide hole for a 6 ft tree but why? 12" hole worked fine... I left plenty of loose soil under the ball. All those trees are 5 yrs old now. I have added some more but just 2 or 3 at a time so I used an old invention called a spade......I did see on ebay a yanmar tree spade. Way cool looking machine.......
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
2017 Kia Sedona LX SUV (A51694)
2017 Kia Sedona LX...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2017 TAKEUCHI TB240 EXCAVATOR (A51246)
2017 TAKEUCHI...
KUBOTA ZD1211 (A53084)
TEST YOUR BID BUTTON! (A51248)
TEST YOUR BID...
