Digging post holes with my BX2200
/ Digging post holes with my BX2200 #1
upgw
SE PA
2001 Kubota BX2200, 2011 Hustler Super Z 31 Kawi
FYI - For those putting fences or trees in. I bought a 'Work saver' post hole digger. Category 0 for 'light duty' but it sure looks well built. The dealer put a Rhino (different company) 9" bit on it because it's much heavier duty than WorkSavers bit. It has double thinkness flutes (or whatever you call them). The dealer cut and shortened the auger shaft because the BX2200 is a little 'short in the pants'. I dug a bunch of holes in rock hard clay to a depth of 34 inches with the engine just above idle. Went very smoothly. The only problem is you have only about 3 inches of clearance when the 3PH is fully raised, so the bit can drag when moving around.
- Patrick W.
/ Digging post holes with my BX2200 #2
I have the same post hole digger, but with the Worksaver bit. I have had some trouble breaking through hard-pan areas. Does the Rhino bit handle hard-pan well?
The dealer recommended this bit because its got this nasty looking 4 inch point on it, like a self-tapping screw. He said it digs in much better than bits without it. The ground I was digging in was so hard (no real rain in months) that the dirt coming up was nearly powdered. I think it would work on 'hard pan' (is hard pan just compacted clay?)
- Patrick W.
/ Digging post holes with my BX2200 #4
Yes, here in the piedmont Carolinas it is very hard clay, especially during drought conditions.
Can you post a picture?
UNUSED KJ - K1912 - 20' X 12' LIVESTOCK METAL SHED (A60432)
UNUSED KJ - K1912...
UNUSED INDUSTRIAS AMERICA F10 TILT LAND LEVELER (A60430)
UNUSED INDUSTRIAS...
2021 CATERPILLAR 259D3 SKID STEER (A60429)
2021 CATERPILLAR...
2020 DRAGON ESP...
Harper TV130 High Dump Turf Vacuum Sweeper (A59228)
Harper TV130 High...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
