Digging a ditch
/ Digging a ditch #21
Slippy I just built a four car garage onto my house and I used it to check the level of the walls and to get the crusher dust level before I poured the slab. I have a sloped driveway going to the garage and as I pour the new driveway I can use it to help me keep the same slope. I have found though that if i can get by with it that it is a lot easier to use it at night that way i can see the laser beam right on the stick and not have to play with moving the detector up and down.
/ Digging a ditch #23
I think you mentioned a 3 point hitch scoop early on in this thread. Have you looked more at this option? While I would think a dirt pan such as a Hoelscher DB-4 or the Durabuilt DP-60 would be the fastest way to do the job you mention, but they are pricey and put a good pull on the tractor, but then so does a back blade when you are trying to move the dirt to a whole other area. The scoop gives you the ability to dig and haul without having to drag it all the way, which in my experience means I lose some along the way with virtually every drag.
Hoelscher site: Hoelscher Commercial Products - DB Scraper
Dirt Scoop: King Kutter Reversible Dirt Scoop — 30in., Model# DS-30 |Category 1 Attachments | Northern Tool + Equipment
The scoop holds 9 cubic feet or about 1/3 yard
/ Digging a ditch #24
Good idea, never thought about using it at night.
EZ Guide 500 Remote (A65640)
EZ Guide 500...
(4) Yetter Trash Wheels and Cutter (A65640)
(4) Yetter Trash...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
INSPECTION (A65583)
INSPECTION (A65583)
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
2022 EZ-GO ELITE...
