Diffy housing change by self
/ Diffy housing change by self
I finished it and then put it back together. Everything worked when I put it back together. Then I was using it and the new housing cracked. So I raised up the brush hog and put a bar under the hyd arms and made the 50 into the most expensive lawn mower in town. The only thing that I can do with the tractor is mow. But at least I can cut things down (weeds).
I was able to seal the cracks with a filler and I can get the hydrolic arms to rise and fall normally. So what I do is raise the arms to get the implement on then I lower it down onto a steel bar to take the weight. I feel that I can do this until it cracks more. By then it will be time to get a new tractor.
2021 Cub Cadet Ultima ZT1 50in. Zero Turn Mower (A64557)
2021 Cub Cadet...
2007 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRK (A64277)
2007 FREIGHTLINER...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
2004 Case JX75 (A64126)
2004 Case JX75...
Skid Steer Hitch Plate (A65640)
Skid Steer Hitch...
