Difficulty Greasing BX25 Swing Frame Pins
   / Difficulty Greasing BX25 Swing Frame Pins
Yea well when I was first told to try a new fitting I laughed to myself since it would take grease when not in the backhoe.
I literally only changed it to a new one and it worked easily. Also swapping one from a different place on the tractor didn't help.
I tried everything else before, lifting rotating, pushing down and nothing else worked.
There is another thread somewhere and the same solution solved their problem too.
Don't forget, I can grease both pins while swinging side to side; it's not the fittings. Read the thread in Skyco's link. Quoting him, "The pin is so dang tight I had to use around 5000 lbs of force with a mini ram to push it out*." This is just a tight fit. I can fix this.
   / Difficulty Greasing BX25 Swing Frame Pins #12
That wasn't the article I read. But in that case I can definitely understand that.
I just know mine was just a new fitting and it was all well for me.
   / Difficulty Greasing BX25 Swing Frame Pins #13
Get yourself a high(er) pressure grease gun. I use a Lincoln 1135. It'll generate up to 7500Psi. There are few fittings that I cant grease. You can try moving the hoe left and right as well.
There are also fitting cleaners that use a hammer and oil to clean out gummed up zerks and pins. Changing the zerk might work too
IH Farmall 504 Tractor (A50514)
IH Farmall 504...
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
2014 JOHN DEERE GENERATOR SET (A51222)
2014 JOHN DEERE...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
2007 Toyota Camry (A50324)
2007 Toyota Camry...
John Deere GP Tractor (A50514)
John Deere GP...
