Oil & Fuel Differential
   / Differential #1
The lost one
ontario
massey 165
Not sure of where to check the differential oil on my massey 165 any help would be appreciated.
   / Differential #2
There should be a dipstick on the right side, behind where your right foot sits on tne floor board.
   / Differential
that is for my hydraulic oil is it the same oil for both
   / Differential #4
It has a common reservoir. Make sure you are on level ground. Order yourself a set of manuals, either your dealer, or agcopubs.com
   / Differential #5
G,Day.
Use universal tractor oil in both the engine and transmission and hydraulics and differential are all common,filler point is next to the gearsticks.
Dont forget to check the planetary drive units ,one each side behind the rear wheels,the filler /level plug faces the rear of the tractor use 85/140 gear oil.
Hutch.
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
