Oil & Fuel Differential
   / Differential #1
The lost one
ontario
massey 165
Not sure of where to check the differential oil on my massey 165 any help would be appreciated.
   / Differential #2
There should be a dipstick on the right side, behind where your right foot sits on tne floor board.
   / Differential
that is for my hydraulic oil is it the same oil for both
   / Differential #4
It has a common reservoir. Make sure you are on level ground. Order yourself a set of manuals, either your dealer, or agcopubs.com
   / Differential #5
G,Day.
Use universal tractor oil in both the engine and transmission and hydraulics and differential are all common,filler point is next to the gearsticks.
Dont forget to check the planetary drive units ,one each side behind the rear wheels,the filler /level plug faces the rear of the tractor use 85/140 gear oil.
Hutch.
2010 Chevrolet HHR SUV (A51694)
2010 Chevrolet HHR...
2021 Triple Crown U6X14T 14ft T/A Flatbed Trailer (A51694)
2021 Triple Crown...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2011 International ProStar T/A Day Cab Truck Tractor (A51692)
2011 International...
2011 IHI IC-75 Weld Deck Crawler Carrier (A52384)
2011 IHI IC-75...
