Differential rear lock
   / Differential rear lock #11
The wheels MUST spin a little or the locking mechanism won't align. The alignment of the mechanism occurs when one tire spins faster than the other. You just don't want it to spin fast enough to grind. If it's grinding.. well.. that's bad.
   / Differential rear lock #12
Or, if you can anticipate the use of the rear lock and are not stuck yet, turning the steering wheel either way while moving will cause one wheel to rotate faster than the other. Light pressure on the lever will allow the wheels lock easily.
   / Differential rear lock #13
Maybe actionaj was referring to engaging the 4wd while the tractor is standing still but the rear wheels are spinning..
It can start an annoying grinding sound that leads up to a clunk followed by sudden forward movement. At least that's how it works on my old pickup. :D
   / Differential rear lock #14
Yes, just don't engage the lock if the rear wheels are spinning.
I've done this several times and haven't seen any adverse problems. I'm in 4wd and am tillering a field. The tractor slows as it hits some soft ground and the rear wheels start to slip more then usual. I depress the diff lock and the tactor seems to grab and I get through the soft soil and then I get off the diff lock and continue.
Perhaps I'm doing something wrong? To me, this seems very normal. :confused:
   / Differential rear lock #15
Here's what the b series (B2x20) manual says:
+When using the differential lock, always slow the engine down.
+To prevent damage to the power train, do not engage diff lock when one wheel is spinning and the other is completely stopped.
+If the diff lock cannot be released in the above manner, step lightly on the brake pedals alternately.
I never slow down the engine and have never tried the brake thing. I just let off the HST pedal some I think, then step on the diff lock. I don't really know if one wheel is completely stopped but so far I haven't heard any grinding.:)
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2008 Ford F-150 Ext. Cab Pickup Truck (A50323)
2008 Ford F-150...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52128)
2023 New Holland...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
