Differential Lock
   / Differential Lock #1
Markashultz
Kioti CK20S
The differential Lock lever on my Kioti CK20s has all but seized as if it needs grease. There is really no way to grease it unless the housing is took apart(i assume) Has anyone heard of this problem on the Kioti, or in general?
   / Differential Lock #2
Welcome, A little searching…
   / Differential Lock #3
I will, occasionally, use the diffy lock on my M6040. Step down on the lever. Some times it will not disengage until I stop the tractor. Then it will pop back up. Try backing up - with the tractor in 2WD.
   / Differential Lock
Thank You All...
   / Differential Lock #5
Internally, it's lubricated with transmission oil, externally, it's not so soak it down with PBlaster or a mix of acetone and red ATF and let it sit for a while and keep it lubed up. Easy fix. I bet the tractor is filthy too. All that filth under there promotes corrosion.
   / Differential Lock #6
On my CK4010SE I've had the diff lock seize up completely. I could stand on it and it would not engage. The only thing I could see to lube was where the shaft goes into the transmission. I sprayed that down with WD40 or PB Blaster (whatever was around, I don't remember) and that was all it took. Went right back to working as it should. Hope that helps!
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A49461)
2014 MultiQuip...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
