differential lock Yanmar 1300
   / differential lock Yanmar 1300 #1
kmosabe
Springfield MO-Ozarks
Yanmar 1300 Original/beautiful
I have a Yanmar 1300, was doing some snow removal with the blade. The left rear wheel was spinning, I hit the differential lock and the left wheel still spun. I thought this would lock the spinning wheel. I know these things get stuck, have not investigated this yet. Also from prior threads, I noticed these things seem to appear not to be activated when you step on them. When I step on mine, it appears not to move much. Is it only activated while you step on it and then upon letting off of it, is is deactivated? Little tractor did a good job, was my first major use of the tractor clearing the driveway; also spent an hour pulling kids tube around. Thing is not 4WD but yet never got stuck.
   / differential lock Yanmar 1300 #2
I'm going to take a guess and say your diff-lock didn't engage because you stepped on the pedal WHILE one wheel was spinning. Try again, but next time push in the clutch, or otherwise stop the left wheel from spinning.... THEN try engaging the diff-lock. Pretty much as you suspected otherwise, when you let up on the pedal, it should unlock once the wheels are free to differentiate.
   / differential lock Yanmar 1300 #3
Good idea to also keep it going in a straight line while the lock is engaged. You can take your foot off the pedal and it will stay engaged as long as there is pressure on it. You can see the pedal pop back up when it releases.
Bruce
   / differential lock Yanmar 1300 #4
If the pedal went down and it did not engage, it's likely damaged. It's not designed to be activated while a wheel is spinnning. You may have trashed the gear that engages it by doing so....we've seen that done. If so, besides finding the parts, there is a day's labor in the tear down and repair.
RULE OF THUMB: DON'T assume you know everything. By the grace of the Yanmar Tractor GODS, there was a reason the pedal was stuck, because I did not know EXACTLY how this operated. Being, stuck, it would not engage. I used some WD 40, got it unstock, took it out on the ice and activated it like I should have. All worked. Thanks for the great advice, love this site.
   / differential lock Yanmar 1300 #6
glad to see you figured it out & got it working.
   / differential lock Yanmar 1300 #8
Mine too was stuck when I got the tractor. It did take some time for the lever to really free up. The lever needs to spring back on it's own, so keep lubing and working it by hand until it's free. When you engage the diff lock, it does take a moment for it to engage. There is some initial travel while the slack is taken up. If you are going straight ahead, it will take some wheel slippage for the mechanism to align. Once aligned the pedal will drop to the floor plate. You need to keep pressure on it or the pedal will release once the pressure is off the gears. After a while, you'll see when you need to step on the pedal again to keep it locked. Generally I try to anticipate the need for the diff lock and engage it before actually need the feature. Don't forget that it can be hard to steer with the diff locked. 4wd definetly helps to pull the tractor around. You can also use the wheel brakes to help steer the tractor.
   / differential lock Yanmar 1300 #9
Cord, I don't understand this. If the differential is locked, how can the wheel brakes help steer it? When you put on either brake, won't it lock both wheels since the differential is locked? I have a 2 wd, does a 4wd somehow work differently?
   / differential lock Yanmar 1300 #10
You should only use the differential lock when travelling straight ahead or you can damage it.
Tennant S30 Ride-On Industrial Floor Sweeper (A51691)
Tennant S30...
2016 Ford Escape SUV (A51694)
2016 Ford Escape...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A51692)
2014 Ford F-450...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2013 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A53426)
2013 VOLVO...
2014 Jeep Grand Cherokee SUV (A51694)
2014 Jeep Grand...
