differential lock shaft seal HELP
   / differential lock shaft seal HELP #1
reidkrabill
iowa
455 john deere
I am buying a 455 john deere later this week...the dealer gave me the option of buying as is or buying it already repaired. It could save me atleast a couple hundred dollars but they haven't got back with me on the final numbers. Based on what they told me I believe it needs a differential lock shaft seal. How hard is this to replace? Thanks.
   / differential lock shaft seal HELP #2
I just did mine last summer. It is not a difficult job or expensive part but you should set an afternoon aside for the project.
I elected to drop the transaxle to reach the seal instead of trying to get my fat fingers in the limited space between the frame, plumbing and linkages. In either case you need to remove the seat and fenders.
Read the TM a couple of times before you start and you should be fine.
Best regards, Alan
when you say TM are you referring to a manual? If so I don't have one. What other seals should I replace while I have the transaxle out?
70pc 12ft.x 3ft. Grey Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
2014 UTILITY 4000DX 53FT DRY VAN TRAILER (A54607)
2014 UTILITY...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A55218)
2019 Energreen EVO...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
