Differential Lock Questions On New Tractors
   / Differential Lock Questions On New Tractors #1
MAHINDRA OF OHIO
Medina Ohio
MAHINDRA
Would you buy a new tractor if it did not have differential lock? Some new tractors coming out do not have differential lock! This of couse makes them about $500.00 less.
   / Differential Lock Questions On New Tractors #2
What models are we talking about?
For me in an ag tractor, no I would not. A CUT or SCUT I don't see that it would make much difference. I don't think mine on my 1433v has ever been engaged. On my bigger tractors it useful in some situations,
   / Differential Lock Questions On New Tractors #3
I don't think so. Only been two times I've been up close when a tractor was pulling or pushing something stubborn. Both times the job was accomplished because of a locking differential. Gobs of torque and lots of mechanical advantage aren't worth much if there isn't enough traction.
   / Differential Lock Questions On New Tractors #4
No, I would not. Traction is key, and the more the merrier.
Is a diff lock standard on the 1500 series? ( 1523??)
   / Differential Lock Questions On New Tractors #5
I don't think I would.
Which tractors are being made without them?
   / Differential Lock Questions On New Tractors #6
I have a GC & it only has 7 hours on it. I've used the diff lock a half dozen times. It's been engaged when I was plowing snow. Granted traction sucks with such little turfs without ballast and / or chains.
   / Differential Lock Questions On New Tractors #7
One of the main reasons I bought the GC2300 was the 4WD and rear diff lock. I need it and have to have it otherwise a tractor is useless to me. I used mine several times yesterday blowing snow, but I also use it on the steep slopes around here all year long whenever I loose traction. It's a must have for me.
DEWFPO
   / Differential Lock Questions On New Tractors #8
Now that I've used the diff lock, I'll never own another tractor without it, of course at 64 I probably have all the tractors I'll ever own.
   / Differential Lock Questions On New Tractors #9
I use the diff lock on my 2310 on a regular basis. It would be tough if it didn't have a lock. Even if it had differential brakes I would still want to have the lock. Still on my list to add, differential brakes to my 2310.
Doug
   / Differential Lock Questions On New Tractors #10
Like the others have said, it's a pretty useful feature on a CUT. I use it all the time when moving snow. Sometimes when moving dirt and quite a bit back when I disced my entire property. It's just another way to get traction to the ground.
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2013 Peterbilt T/A Heil 28Yd Side Loader Garbage Truck (A50323)
2013 Peterbilt T/A...
2012 Case 850L XLT Dozer (RIDE AND DRIVE) (A50774)
2012 Case 850L XLT...
Case-IH Engine (A50121)
Case-IH Engine...
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
2011 Manac 36245B30 45ft T/A Walking Floor Trailer (A50323)
2011 Manac...
