Differential Lock Questions On New Tractors
   / Differential Lock Questions On New Tractors #1
MAHINDRA OF OHIO
Medina Ohio
MAHINDRA
Would you buy a new tractor if it did not have differential lock? Some new tractors coming out do not have differential lock! This of couse makes them about $500.00 less.
   / Differential Lock Questions On New Tractors #2
What models are we talking about?
For me in an ag tractor, no I would not. A CUT or SCUT I don't see that it would make much difference. I don't think mine on my 1433v has ever been engaged. On my bigger tractors it useful in some situations,
   / Differential Lock Questions On New Tractors #3
I don't think so. Only been two times I've been up close when a tractor was pulling or pushing something stubborn. Both times the job was accomplished because of a locking differential. Gobs of torque and lots of mechanical advantage aren't worth much if there isn't enough traction.
   / Differential Lock Questions On New Tractors #4
No, I would not. Traction is key, and the more the merrier.
Is a diff lock standard on the 1500 series? ( 1523??)
   / Differential Lock Questions On New Tractors #5
I don't think I would.
Which tractors are being made without them?
   / Differential Lock Questions On New Tractors #6
I have a GC & it only has 7 hours on it. I've used the diff lock a half dozen times. It's been engaged when I was plowing snow. Granted traction sucks with such little turfs without ballast and / or chains.
   / Differential Lock Questions On New Tractors #7
One of the main reasons I bought the GC2300 was the 4WD and rear diff lock. I need it and have to have it otherwise a tractor is useless to me. I used mine several times yesterday blowing snow, but I also use it on the steep slopes around here all year long whenever I loose traction. It's a must have for me.
DEWFPO
   / Differential Lock Questions On New Tractors #8
Now that I've used the diff lock, I'll never own another tractor without it, of course at 64 I probably have all the tractors I'll ever own.
   / Differential Lock Questions On New Tractors #9
I use the diff lock on my 2310 on a regular basis. It would be tough if it didn't have a lock. Even if it had differential brakes I would still want to have the lock. Still on my list to add, differential brakes to my 2310.
Doug
   / Differential Lock Questions On New Tractors #10
Like the others have said, it's a pretty useful feature on a CUT. I use it all the time when moving snow. Sometimes when moving dirt and quite a bit back when I disced my entire property. It's just another way to get traction to the ground.
2014 Nissan Rogue Select (A51694)
2014 Nissan Rogue...
City of Lakeland (A51691)
City of Lakeland...
2018 GMC Savana (A50120)
2018 GMC Savana...
20' Deer Gates (A50121)
20' Deer Gates...
2019 John Deere 6175M (A50120)
2019 John Deere...
2018 Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
2018 Caterpillar...
