Oil & Fuel Differential fluid fill
   / Differential fluid fill #1
jmonahan43
Osage, Ar.
Ford 5000
Newbie here, and I recently bought a Ford 5000 and I would like to know how to check the differential fluid level, and if it is a common sump with the 3 pt hitch hydraulics. I have downloaded the maint. manual, and an owners manual but they don't show the fill and check locations.
What type of fluid should I use?
Thanks,
Jim
   / Differential fluid fill #2
use m2c134d or equvalent oil. keep in mind this machine is wet brakes.
very late 75 models and I think, models with DP will be all common sump front to rear., like a 5600. other than that, seperste sump with diffy and hyds common.
aft of the seat is a big bung plug to add oil.. and if standing behind the tractor, facing the back of it, on the left side axle trumpet will be a big pipe plug.. that is the level check.... add oil till it starts dribbling out there..
a 5000 is a fine machine... you can date it from the numbers stamped on the bellhousing aft of the starter..
soundguy
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2017 Kubota L4701 (A57148)
2017 Kubota L4701...
Deere 310L (A53317)
Deere 310L (A53317)
John Deere Gator (A53317)
John Deere Gator...
SARLO MOWER (A55758)
