Different types of Oil???
/ Different types of Oil???
I am still waiting to hear an answer to what this statement means...... /forums/images/graemlins/confused.gif
</font><font color="blue" class="small">( The (Rotella) 15W-40 is dino based oil and the 5W-40 is supposed to be hydrocracked dino that they can legally market as synthetic. )</font> .
/ Different types of Oil??? #22
I made that statement basing it loosely on the Castrol Syntec legal situation. I think it was Mobil that sued claiming that Castrol Syntec wasn't "synthetic" enough to carry that label. Castrol won and still sells Syntec as a "full synthetic" oil. I have the opinion that most of this is just a lot of creative marketing on the oil company's behalf and a hydrocracked oil isn't really as good as a PAO based oil, but since you can't just create matter out of nowhere, you have to start with something to refine into synthetic lubricants. As the others who are more knowledgeable than me on this subject stated above, that happens to be petroleum base stocks also. It is definitely one of those "gray area" issues. My understanding is that Rotella synthetic is hydrocracked and Mobil Delvac is a PAO. Does anyone know this to be true or false?
Jeff
/ Different types of Oil??? #23
Some high pressure hydrotreated oils are virtually equal in performance to PAO type oils. Exxon developed a HP hydrotreat process and installed the equipment in its Baytown, TX refinery (largest lube oil plant in the world) just about the time I retired in 1998. Just about that time they were also started negotiations with Mobil to merge. So, with availability of the almost ideal oil in a PAO available from Mobil, guess they decided to not make a big marketing deal out of their new oil. I suspect they're just blending it into the stuff that they can up in Baytown. That was one of the options, but with lower payout, as it reduces the amount of additive they have to use to make canned oil specs.
For instance, canned oil specs are generally about 140 VI (viscosity index) vs. about 100 VI from the straight solvent-processed, lightly hydrotreated oils. This new special hydrotreated oil was very close to 140 VI and therefore needed little VI improver. Think its pour pour was still a tad high, maybe around 0 vs. -40 needed in the canned oil and about what the natural pour is for PAOs. It still needed some pour point depressant, some detergents, etc.
They might have chosen to sell some of this new type oil to outfits like Castrol that used to buy almost all its oil from Exxon/Esso. This may be the stuff some of those outfits are canning up. Some other manufacturers likely developed their own similar processes as well. Think Chevron had a similar one that Exxon thought hard about licensing.
It's been near 5 years since I retired. Other things could have happened.
Ralph
/ Different types of Oil??? #24
</font><font color="blue" class="small">( well I do believe that synthetics are better protection. Why else would the top end car makers ask you to use them. Sure you can get 200,000 out of a car on dino but how good is the power compared to when it was new. Proof for me who USED to believe synthetic was a rip off was watching drag racing;John Force came out of his funny car laughing his *-# off. the camera guy asked why John replied he made his burnout and full run with zero oil presure the engine was fine. I was sold, if a 1000 hp. + engine could live like that there was something good in synthetics. /forums/images/graemlins/grin.gif )</font>
That sounds like a severe test, but is it? At 9000 rpm for 4.5 seconds, that engine revolved a whopping 675 times without oil pressure. Double, triple, or quadruple that number to include burnout, etc, and you still don't have much. Admittedly, it is a high-horsepower situation (probably more like 6,000 hp, not 1,000) but the time spend under power is very short. I wouldn't put a lot of stock in synthetics because of John Forces zero oil pressure run. It may have been that only his gage was erroneous.
Also, most of the tests advertised as 'torture testing' by various organizations are anything but that. Vehicles that accumulate running time rapidly without cooling cycles in between are the easiest type of duty an engine can see.
Are synthetics worth it? Probably not for most people, especially if you are still required to change oil at the interval specified by the manufacturer (during warranty). Once you're out of warranty, synthetic oil can withstand extended drains more favorably than dino, but it would seem that the filter would still need changing at the original interval. If I have to get under there to change a filter, I might as well just change the oil while I'm at it. To me, changing the filter is always the worst part of it.
/ Different types of Oil??? #25
castrol and mobil have spent millions to confuse the synthetic engine oil market. mobil uses a true pao synthetic base oil for their mobil 1, whereas castrol syntec and chevron delo 400 synthetic 5w-40 use a group III ucbo(unconventional base oil) which is not truely a traditional synthetic but qualifies since it exhibits synthetic characteristics. a synthetic oil can reduce wear in any engine when compared to a conventional mineral oil since it has a naturally higher viscosity index (the ability of an oil to maintain its viscosity over a wide temperature range). keeping in mind that viscosity is directly related to the film of oil between moving surfaces, the higher the vi, the better the film strength, the less wear. oil is not oil, grease is not grease. there are major differences. even synthetics are not synthetics. if someone is really dedicated maximizing engine life, then use primrose duragard armor plate with moly-d . it is available in staight weights and multi-viscosity. it controls the corrosive effects of acids better than any other oil and contains a patented proprietary form of molebdenum called moly-d that eliminates wear, increases power, and improves performance. it just seems that people who use their products never have problems.
/ Different types of Oil??? #26
</font><font color="blue" class="small">( Yes, the good old oil debate /forums/images/graemlins/smirk.gif The only ones I'd rather read about are the Husky-Stihl and the HST-gear debates. )</font>
Bottome line ... Synthetics are <<snip.. snip..>>
<cut> <snip> PERIOD.
Now on to the real purpose of my post...
Stihl is the greatest.
HST is the best transmission type I have ever used!
</font><font color="blue" class="small">( ..........Bottome line ... Synthetics are <<snip.. snip..>>
HST is the best transmission type I have ever used! )</font>
My Husky is better than your Stihl any hour of any day of any week of any month of any year of any decade for many decades to come!!! /forums/images/graemlins/shocked.gif and your dog wears combat boots!!!! /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif LOL /forums/images/graemlins/wink.gif We now return to the debate of the oils after this commercial message from your local advertiser.
/ Different types of Oil??? #28
Yea you might think that John Force in his 1000+ hp funny car with the lack of oil presure was for a short time(it turned out he did have a bad pump) but if ya add up the time for a burn out pre stage and the run thats alot of time for no oil 20 seconds? probebly no one will change the oil that they use, synthetic fans or dino fans but for all the money in an engine I will spend an extra$5 at walmart for rotella synthetic why wear out an engine sooner, keep the power you get from day one. /forums/images/graemlins/grin.gif
/ Different types of Oil??? #29
alpha, kinda the same reasoning why I just recently converted over to synthetic. Price difference is negligible when you look at the total annual family budget. There's no denying that it is the superior lubricant in extreme conditions...simple chemistry and physics. The only point of contention is whether or not it provides any benefit for our mostly non-extreme applications in CUT's and pick'em up trucks.
Benefits are most likely unmeasurable in the majority of applications, unless the equipment was specifically designed for syn oil. And independant studies are sorely lacking. But, from a chemistry/scientific/physics point of view, there's no doubt it is superior. I don't think anybody debates the ultimate superiority of syn., just its superiority in a given situation.
So....Again...bottom line...it comes down to what makes you feel good....'cause none of us can prove beyond a reasonable doubt whether dino or syn will help out tractors/trucks last longer.
Here's why I decided to spend an extra few bucks a year on syn. : I just recently bought an 04 new-design F150. Oil requirement is 5W-20 (as many Ford engines have gone to).
The owner's manual got a little free advertising by stating fairly strongly that they recommended their Ford synthetic blend 5W-20 oil.
So, if Ford really wishes I would use a syn. blend, why not go one small step better and go 100% syn.? Plus, by doing it myself rather than using the dealership, I will still come out ahead.
Anyway, there's still some uncomfortable feelings deep inside about that watery 5W-20 oil....I know, it shouldn't be there with today's oil technology, but it is.
r
/ Different types of Oil??? #30
I assume dino means dinosaur, which would refer to the good old mineral based petroleum oil that comes from the ground. the 5w-40 hydrocracked oil is still mineral based, but is much more refined. the hydrocracking technology was developed by chevron and basically takes most of the impurities out of the base oil that would otherwise cause it to oxidize more rapidly. the better base oil has enabled the major oil co. to produce lubes that can be considered "synthetic", but only in performance and not in method of production. a true synthetic motor oil will cost around $20-$25 per gallon, whereas the imitation synthetics run around 14-16.
/ Different types of Oil??? #31
Congrats on your new F150. I have a 97 F150 that has had synthetic since break-in. FYI, there has been no (significant) change in engine technology / manufacturing that requires the use of 5w20. The consensus of (most) folks at the FordF150.net forums is to continue the use of 5w30. The switch to 5w20 spec was <font color="red"> soley </font> to boost mpg of the ford fleet to meet federal specs. Take a look at the numbers and you will see that 5w20 is pretty thin stuff. I personally don't want a marginally lubricated engine (IMHO) just so Ford can increase their fleets mpg by a few tenths.
/ Different types of Oil??? #32
Only slightly o/t here, but I was watching hte history channel yesterday, and they had a great program on about 'air raids of WWII'.
In it we were bombing mostly ball bearing factories in germany ( I had no idea we were so close to shutting down the german military machine by bombing BB factories. according to the show, at one point, germany had 2 months of stored BB and after that they would be out.. and if we had bombed just a few more days during one crucial airstrike.. that may have been the end of it).
Anyway on to the topic.. On the show they also showed that we bombed synthetic oil factories in germany... Wow.. I didn't know anyone was working on syn oil back in the 40's...
Soundguy
/ Different types of Oil??? #33
Yep, they needed the synthetic 'cause they had no source for dino.
I guess no-one should feel too bad about 'flaming' in the forums when you think back and realize that world and local wars are oil based!
/ Different types of Oil??? #34
Yup, you can thank go-old Hilter for synthetic oil. Nice ha. I remember hearing that several years ago in college and I was amazed then and still am.
/ Different types of Oil??? #35
BobCorazza,
I agree that the changes to the 04 5.4 L vs the heritage were minor. The only significant changes I know of us going to 3 valve/cylinder to help it breathe better and an electronically adjustable cam. So, newest 5.4L engine puts out a little more hp and torque with a flatter curve that was shifted further toward the lower RPM range...at least that's what I remember. Nothing 'revolutionary'. I can't see those changes necessitating a thinner oil.
I read the same thing about 5W-20 being specified only to squeeze out a tiny bit more mileage. I plan to go to 5w-30 before long. I'll have to wait a little while though. When I last ordered some Amsoil 5W-20, I ordered enough for 2 oil changes...so I have one more change to go...then will probably go to the 5W-30 2000 series (I was dumb and bought that 7500 mile oil 1st time...should have paid just a little more for the 2000 series). But, I will stick to a ~5000 mile oil change interval....makes me feel more warm and fuzzy inside and I won't have to worry about warranty issues in the very slim chance that something ever happens to the engine internals.
Waste of money? Probably. I have never kept a vehicle past 140k mi before...I doubt there's any oil on the market today that wouldn't keep the engine running fine and dandy for that long. But, I'm doing my part to keep the economy going, so eveybody should be excited about us free-spenders.
Cat CB24B (A60462)
Cat CB24B (A60462)
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
Pemberton 6ft Loader Forks and Frame (A59228)
Pemberton 6ft...
(APPROX.48) UNUSED 2X4X16 PRIME GRADE LUMBER (A60432)
(APPROX.48) UNUSED...
iDrive TDS-2010H...
