Tiller Difference in tillers
   / Difference in tillers #1
ustobefarmer
Bronze Member
S. Illinois
Kubota BX 2370
Can any one tell me which would be better. A forward turning tiller or a reverse turning tiller. Looking at either a landpride rta 1250 or rtr 1250 for a kubota 2370.
   / Difference in tillers #2
If you have a lot of rocks;you want them going out the back and not binding up the tiller.
   / Difference in tillers #3
If it is turning forward it will climb over a stump or large roots stone rocks etc. I have had a lot of tillers but one with six cutters instead of four does much better job IMHO.
   / Difference in tillers #4
my opinion,reverse tillers are good for lawn renovation, for field work go with forward till.
It's going to be used in gardens and we have no rocks to worry about.
   / Difference in tillers #6
I have had the Land Pride rtr05 for about 4yrs now. It is a reverse tiller. Basically this means that the tines rotate opposite to the direction if travel. They typically do a better job of tilling than a forward tiller. I use mine behind a bx2360. I like it and it has never let me down. I do find that rocks larger than a melon tend to get jammed between the tines and the housing. Make sure you set the clutch properly to prevent damage.
   / Difference in tillers #7
Would it ve a safe guess that you have the 50" model? After running that machine with your tractor do you feel it maxes out your tractor or could you run a 5' model?
   / Difference in tillers #8
I have an 8hp Troy Bilt tiller. It has reverse rotating tines. It does not leave as smooth a surface on one pass. It is easier to break virgin ground with a reverse rotating tiller. Forward rotation will tend to jump over things - reverse rotation will tend to bring things up to the surface. I prefer reverse rotation.
I use this tiller each spring to prepare my 100' x 75' garden.
   / Difference in tillers #9
Behind a tractor forward tines work just fine and the dust is heading in the right direction.
   / Difference in tillers #10
Land pride has a video on their YouTube channel that shows the difference. I'd link it to you but I'm on my phone.
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52128)
Michelin CARGOXBIB...
John Deere 893 Corn Head (A50514)
John Deere 893...
2014 Chevrolet Tahoe (A50324)
2014 Chevrolet...
CATERPILLAR 320GC EXCAVATOR (A51242)
CATERPILLAR 320GC...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2016 Ford Focus (A50324)
2016 Ford Focus...
