Difference between MF 135 & MF 235??
/ Difference between MF 135 & MF 235?? #1
SCDolphin
Columbia, SC
Kubota L5240: Craftsman GT6500
What is the difference between the 135 & 235? If both same condition is there any advantages of one from the other??
Thanks
/ Difference between MF 135 & MF 235?? #2
Massey Ferguson
135
Manufactured: 1964 - 1975
Cost: (US Dollars) $4385 (1975)
Power:
Drawbar (HP): 33
PTO (HP): 38
Engine:
Manufacturer: Perkins
Fuel: diesel
Cylinders: 3
Bore/Stroke (inches): 3.6 x 5.0
Displacement (ci): 152.7
Compression:
Rated RPMs: 2000
Torque (ft-lbs): 121.7 @ 1300 RPMs
Firing order:
Oil capacity (qts):
Engine:
Manufacturer: Continental
Fuel: gasoline
Cylinders: 4
Bore/Stroke (inches): 3.375x4.062
Displacement (ci): 145
Compression:
Rated RPMs: 2000
Torque (ft-lbs):
Firing order:
Oil capacity (qts):
Engine:
Fuel: gasoline
Cylinders: 3
Bore/Stroke (inches): 3.6x5.0
Compression:
Rated RPMs: 2000
Torque (ft-lbs):
Firing order:
Oil capacity (qts):
Transmission:
Forward: 6
Reverse: 2
Transmission:
Forward: 8
Reverse: 2
Capacity:
Fuel (Gal): 10.2, 12.6 (late)
3-Point:
Category: I
Lift (lbs):
Power Take-off (PTO):
Type: live
Rear speed (RPM): 540
Tires:
Ag front: 6.00-16
Ag rear: 14.9-24
Dimensions:
Weight (pounds): 3645
Wheelbase (inches): 72
Length (inches): 118.1
Width (inches):
Height (inches):
Ground clearance (inches):
2WD turn radius (feet): 19.3
Electrical:
Battery volts:
Ground:
Battery cold-cranking amps:
Alternator amps:
Steering: power optional
Nebraska Test:
Test Number: 895
Test Date: May 1965
Engine: diesel
PTO HP: 37.8
Drawbar HP: 33.1
Max pull (pounds):
Nebraska Test:
Test Number: 899
Test Date: June 1965
Engine: 145 gasoline
PTO HP: 35.4
Drawbar HP: 30.5
Max pull (pounds):
Nebraska Test:
Test Number: 1009
Test Date: April 1969
Engine: 153 gasoline
PTO HP: 37.6
Drawbar HP: 32
Soundguy
/ Difference between MF 135 & MF 235?? #3
Massey Ferguson
235
Manufactured: 1975 - 1976
Cost: (US Dollars) $6,900 (1976)
Power:
Drawbar (HP): 35
PTO (HP): 41
Engine:
Fuel: diesel
Cylinders: 3
Compression:
Rated RPMs:
Torque (ft-lbs):
Firing order:
Oil capacity (qts):
Transmission:
Forward: 8
Reverse: 2
Capacity:
Fuel (Gal):
Cooling (Qt): 0
3-Point:
Category: I
Lift (lbs):
Type: live
Tires:
Ag front: 6.00-16
Ag rear: 13.6-28
Dimensions:
Weight (pounds): 4140
Both specs from tractordata.com
Soundguy
Thanks SoundGuy
/ Difference between MF 135 & MF 235?? #5
Stay away from the MF235...the 135 is a much better tractor, worth more, and parts will be much easier to come by. The 235 is infamous for its steering problems.
/ Difference between MF 135 & MF 235?? #6
Of all the 200 series, for some reason I have never liked the 235. It is not that we had any more problems with them or anything like that, I just don't like them. As far as the steering problems, when we sold them we never had any more problems with the 235 than we did with any of the of the other 200 series tractors. For the number of tractors we sold, we had very few problems.
/ Difference between MF 135 & MF 235?? #7
The 235 was the logical replacement for the 135. Front ends were almost identical. There were SOME issues with steering on the 200 series with the swept-back axle (235) but nothing that a few parts won't take care of. The 245 had a heavier front axle (simular to 150/165/255) It was a BETTER choice when new.
The biggest advantage a 135 has over the 235 is ease of finding parts. Engine/tranny/hydraulic parts are ALMOST the same. The 135 was one of the all-time best selling tractor models. That leads to aftermarket parts out the whazoo.
I'd not shy away from EITHER model at a good price.
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2014 Bayliner 180 Boat with 2004 Venture 24ft T/A Boat Trailer (A59231)
2014 Bayliner 180...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
Broom Attachment (A59228)
Broom Attachment...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
