Difference between Limited CAT1 and CAT1
   / Difference between Limited CAT1 and CAT1 #11
JDFANATIC,
Your good suggestion about adding 5 suitcase weights to the front of the 2305 generated a couple followup questions I had regarding PSI in the front and rear tires...
1) What should be the PSI tire pressure for front and back tires with say these 5 weights and a JD 647 tiller attached??
2) What about a PTO driven spreader attached with front weights?
3) Finally, what are good guidelines for PSI if only a 62" MMM is attached??
thanks much
   / Difference between Limited CAT1 and CAT1 #12
JDTRAC said:
JDFANATIC,
thanks much
JDTRAC,
Good questions. :)
1) On my 2210, I run the max psi on the rear tires (loaded), and about 10 psi over max on the fronts. The reason I overinflate the fronts is that I've almost had them flat on the ground with really heavy loader work (remember, we know a 2210/210 combo will lift 1170# to ~ 16"). This is with turfs; if you run industrials, then you already have more support and I would likely run the max indicated on the tire.
2) I'm not sure what you meant by this, can you clarify?
3) I would go with the max indicated pressure on the tire itself.
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
