Rotary Cutter Difference between "economy" and medium-to-heavy duty rotary cutters
   / Difference between "economy" and medium-to-heavy duty rotary cutters #11
I never used a fail mower, but I would be very suspicious of using one for cutting down saplings??
A flail mower will do a lot better job with small saplings (up to about 2") than a brush hog. Some flail mowers are even reversible so you can have the "front" facing out when you are driving the tractor backwards, which is nice for dealing with heavy brush so that you don't have to drive over it first. Also flail mowers will chop up the woody material better.
   / Difference between "economy" and medium-to-heavy duty rotary cutters #12
FARMWITHJUNK is disabled and is not posting on T-B-N any longer. His is a great loss.
FARMWITHJUNK operated a commercial mowing service.
Re: Contract Flailing
I do commercial ROW mowing as well as several large acreage tracts. We've tried high end flails on several occasions. (Owned one, demo-ed 3 others..) They do an excellent job in many conditions, but require MUCH slower ground speeds in conditions that are very typically found in my line of work. They also require MUCH more HP in what I'd describe as "adverse conditions". As an example, a tractor we routinely use to pull a 15' bat wing (rotary) struggled with an 8' flail in high weeds. Before that draws a comment on "inexperienced operators", ect, I'll say this. We had a factory rep on hand while we used the flails. They were unable to rationalize the disadvantages of the flails. There was also NO comments offered on the way we used them, leaving my with the impression our results were typical.
When I demo-ed those flails, I was high on the idea of promoting them as a way of setting my business apart from the pack. It didn't take long to realize they simply made me uncompetitive in the market I had to operate in. This isn't Utopia...It's a tough economic environment. Operating at a disadvantage is a mistake, no matter what one would LIKE to do.
Initial cost (for higher quality units) is much higher than a heavy duty rotary cutter (per foot). Routine maintenance was off the charts compared to the relatively low cost involved with a rotary cutter.
Cost to mow an acre with a rotary cutter is fairly constant in varying conditions. Cost per acre with a flail varies wildly, and tends to lean towards VERY high per acre cost in the conditions commercial mowing generally presents. That EITHER makes bids unattractive, OR results in low profit margin. I don't know about you, but I'm in business to make money. A charming sales pitch doesn't feed the bulldog.
Much is made of the "safety factor"....Too much in fact. Flails aren't 100% safe, neither is a rotary cutter. With proper precautions, BOTH can be used successfully. There is a higher incidence of accidents with rotary mowers due in fact to the HUGE disparity in numbers of flails vs rotary cutters. This is one instance where numbers (as they're used in sales propaganda) DO NOT tell the true story.
You'll get the "sales pitch" (and associated propaganda) from "someone" on here who has a vested financial interest in selling flails, but speaking strictly as someone who's used BOTH enough to understand the assets AND liabilities of each, I'm holding steady with rotary cutters. There simply is not enough margin of profit in ROW mowing these days to afford a MUCH more expensive mower. (basing on long term use and maint, initial cost, and volume of billable work performed) You'll find flails more commonly in use by municipalities, where cost vs return on investment isn't a consideration. I have no interest in promoting OR criticizing EITHER, just a financial interest in operating MY BUSINESS in the most profitable (but still safe and efficient) manner.
3 years ago, we demo-ed 2 Alamo commercial grade flails. While mowing highway right-of-ways, BOTH required repairs that would have resulted in substantial expense, while mowing a stretch of road we routinely mow with Bush Hog bat wing rotary cutters. (Due to hitting exposed rock hidden under downed weeds) Quite simply put, rotary mowers will take FAR MORE punishment, do a more than satisfactory job, and do it at a much lower operating cost. Anyone who tries to tell you otherwise is simply ignoring/misrepresenting the facts to promote their own agenda.
Flails do an admirable job in select conditions. If you have the luxury of picking and choosing what you mow, fine..... The conditions that caused problems for the flails I saw represent approx. 75% of my business.
In the final analysis, the difference in quality of cut was minimal, if at all, when mowing in like conditions with a flail mower vs a "bush hog". A flail will obviously leave a better "lawn" than a bush hog in "lawn" conditions, but that isn't what is being compared in this thread anyway..... And with this type of mowing , 24 hours after the fact, it's virtually impossible to distinguish which type of mower was used in rough cut conditions.
Another valid point of comparison....Size of mower....I run a fleet of 15' bat wings. To get that width of cut, the typical set-up is to run a rear mounted 3-point flail, PLUS a side mounted hydraulic driven wing flail mower. The hp required, as well as the weight of the tractor serving as a power unit is substantially more demanding for the flails. (and cost goes up as you might expect) Rotary cutters can be run at lower engines speeds than the rated pto rpms with minimal drop off in quality of cut. Flails require (according to manufacturers) full, constant pto rated rpms. We found that recommendation to be "gospel". That's a critical difference when mowing in tight confines or when dealing with vehicle traffic only inches away. It's mandatory we be able to throttle back in certain situations.
BTDT, loaded the shelled flail mowers on a truck and sent 'em back to where they came from with no regrets. I compete against several other mowing contractors for my work....NONE....NOT ONE of them use flails. They simply DO NOT pencil out against a rotary cutter under the typical contract mowing conditions MOST of us are dealing with.......
Flail mowers have their niche. Making claims that they're THE answer to every question tends to make me discount ANY claims being made in their favor.
There are three kinds of men;
1.) The ones that learn by reading
2.) The few who learn by observation
3.) The rest of them have to pee on the electric fence for themselves.
   / Difference between "economy" and medium-to-heavy duty rotary cutters #13
Well that post from Farm withjunk pretty much answered any possible question about flails in tough conditions or hp. Thanks!
New/Unused Electric Golf Cart (A57453)
New/Unused...
PENDING SELLER CONFIRMATIONS (A58018)
PENDING SELLER...
TORO SAND PRO 3020 (A58374)
TORO SAND PRO 3020...
SCALES & PEA (A58374)
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
1" Pneumatic Impact Wrench (A59076)
1" Pneumatic...
